Trim block
Trim block
mohan.b
Trim block
mohan.b
    i have to trim unwanted overlapping object above the block by selecting block. pls refer the drawing.
ВeekeeCZ
Use XCLIP.
Kent1Cooper
No drawing.
Kent Cooper, AIA
mohan.b
Drawing attached. try to give lisp solution in single click trim
Kent1Cooper
If you don't mine a two-pick solution so as to not need a custom command, EXTRIM does that.  You need to pick the perimeter part of the Block, and then pick inside it [only once, and not necessarily on any of the things you want Trimmed] to tell it that's the side of it from which you want things taken out.
Kent Cooper, AIA
ronjonp
@mohan.b
See attached.
