@jwright1962 hi,
Check this DPVP (Duplicate Viewports) command. it requires you to lay the viewports on agreed target layer:
CL#5: (setq VPLAY "vp")
by default it is set to "vp" layer. you can change it here (code line #5) to any other you like. there is no link between the viewport and pline (on model) instead each time you modify the viewport (or plan to plot) run DPVP.
Note:
if you forget to lay all viewports on target layer, you will be alert. viewports that are not on target layer are filtered out and you will not be alert.
the command starts with deleting all old plines on target layer in model space (if they are exist?!) than select all viewports on target layer in current layout.
Nice feature 🤣
the drawing state is saved before process and puts you back where you were (e.g in mspace or pspace).
enjoy
Moshe
(vl-load-com) ; load activex support
; Duplicate viewports
(defun c:DPVP (/ VPLAY adoc savTM sav CVPort ss ename0 ename1 elist0 AcDbPline0 AcDbPline1 sa wht hgt c0 p0 p1 clone)
(setq VPLAY "vp") ; const, target layer
(setvar "cmdecho" 0)
(command "._undo" "_begin")
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
; save drawing state
(setq savTM (getvar "tilemode"))
(setq savCVPort (getvar "cvport" ))
(setvar "tilemode" 0) ; switch to layout
(command "._pspace") ; move to pspace
; delete previous polylines but first make sure layer is on and unlocked
(command "._layer" "_thaw" VPLAY "_unlock" VPLAY "")
(if (setq ss (ssget "_x" (list '(0 . "*polyline") (cons '8 VPLAY) '(410 . "Model"))))
(foreach ename0 (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(entdel ename0)
); if
; Select all viewports on target layer in current layout
(if (not (setq ss (ssget "_x" (list '(0 . "viewport") (cons '8 VPLAY) (cons '410 (getvar "ctab"))))))
(progn
(vlr-beep-reaction)
(alert (strcat "No viewports found on layer \"" VPLAY "\" in current layout"))
); progn
(progn
(setq elist0 (entget ename0))
(cond
((setq ename1 (cdr (assoc '340 elist0))) ; has linked pline?
(setq AcDbPline1 (vlax-ename->vla-object ename1)) ; get it
; get viewport center point
(setq AcDbPline0 (vlax-ename->vla-object ename0))
(setq c0 (vlax-safearray->list (vlax-variant-value (vla-get-center AcDbPline0))))
(vlax-release-object AcDbPline0)
(setq sa (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element sa 0 AcDbPline1)
(setq clones (vla-copyObjects adoc sa)) ; duplicate linked pline
(foreach obj (vlax-safearray->list (vlax-variant-value clones))
(vlax-release-object obj) ; ; dispose memory
(vlax-release-object AcDbPline1) ; dispose memory
); case
( t
(setq c0 (cdr (assoc '10 elist0)))
(setq wht (cdr (assoc '40 elist0)))
(setq hgt (cdr (assoc '41 elist0)))
(setq p0 (list (- (car c0) (/ wht 2)) (- (cadr c0) (/ hgt 2))))
(setq p1 (list (+ (car c0) (/ wht 2)) (+ (cadr c0) (/ hgt 2))))
(command "._rectangle" "_None" p0 "_None" p1)
); case
); cond
; send it to target layer
(command "._chprop" "_si" (entlast) "_Layer" VPLAY "")
(command ".mspace") ; switch mspace
(setvar "cvport" (cdr (assoc '69 elist0))) ; make it current viewport
(command "._pspace") ; back to pspace
; send it to mspace
(if (= (sslength ss) 1)
(command "._chspace" "_si" (entlast))
; else, there are more than 1 viewport on layout
(command "._chspace" "_si" (entlast) c0 "")
); if
(command "._pspace"); back to pspace
); foreach
); progn
); if
; restore drawing state
(if (> savCVPort 1)
(progn
(command "._mspace")
(setvar "cvport" savCVPort)
); progn
); if
(setvar "tilemode" savTM)
(vlax-release-object adoc) ; dispose memory
(command "._undo" "_end")
(setvar "cmdecho" 1)
(princ)
); c:DPVP
