Clipped vewport via bpoly issue
danglar
danglar
Usually I need to clip view port like it shown on picture.
I do it by following steps
1. use BPOLY command in order to create closed polyline
2. use VPCLIP command to create polygonal clipped viewport
Is it possible to automate this process and do these steps via lisp?
Lisp can ask internal point to create closed polyline and ask which viewport need to clip
and return clipped viewport like it shown on the picture
Any help will be very appreciated
ВeekeeCZ
I don't use this workflow so... just try.
(defun c:BVPORT ( / enl)
  (setq enl (entlast))
  (setvar 'HPISLANDDETECTIONMODE 1)
  (command-s "_.BOUNDARY")
  (if (not (equal enl (entlast)))
    (command "_.VPCLIP" PAUSE (entlast)))
  (princ)
Adjust an islanddetection as you with.
danglar
First of all thank you
for your rapid question
I just have a trouble to select viewport in VPCLIP command because a boundary polyline placed above viewport..
any suggestions will be appreciated
ВeekeeCZ
We can either send the pline back or we can change the workflow to let you select a viewport first (or even pre-select)
danglar
not matter how we can do it but I prefer a possibility to select viewport after creating boundary
Probably something like this?
 (command "DRAWORDER" "L" "Back")
ВeekeeCZ
If a command allows selecting more objects, as the boundary does, you need to close the selectionset.
    (command "_.DRAWORDER" "_L" "" "_Back"
             "_.VPCLIP" PAUSE "_L"))
  (princ)
danglar
Perfect solution!
I just forgot about draworder selecting mode (more than one object per session):)
Thank you very match. Your solution will save me a lot of time to prepare layouts
