find polyline intersection lengths based off of user selection
Message 1 of 8
This should be an easy task for those versed in Lisp. What I need is to find the lengths of a polyline at the intersection points. Lee Mac's program (http://www.lee-mac.com/intersectionslength.html) is close but perhaps a picture will better explain the output I'm looking for. (see attached) I want the total length from point A to the first intersection point as Length 1. Length 2 = the distance along the polyline from point A to the next intersection point. Likewise with points 3 and 4. the program need to be intelligent enough to recognize how close the crosshairs are to point A or point B and spit out the lengths based on the proximity. So if I select the polyline closer to point B, the values shown would be from B to A. Or if I selected the polyline closer to A, then all the measurements would be from A to B.
This should be a simple tweak of what Lee Mac has already done but I'm not a programmer. Any help is always appreciated.
Replies (7)
Message 2 of 8
ВeekeeCZ
It looks like it works... but no more.
;;-------------=={ Length Between Intersections }==-----------;;
;;  Displays the length of segments of a curve divided at     ;;
;;  intersections with other objects.                         ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.4    -    26-04-2011                            ;;
(defun c:IntLen ( / *error* _iscurveobject e )
  (defun *error* ( msg )
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _IsCurveObject ( entity / param )
    (and
      (not
        (vl-catch-all-error-p
          (setq param
            (vl-catch-all-apply 'vlax-curve-getendparam (list entity))
      param
  (if (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
    (princ "\n--> Current Layer Locked.")
    (while
      (progn (setvar 'ERRNO 0) (setq e (car (setq sel (entsel))))
        (cond
            (= 7 (getvar 'ERRNO))
            (princ "\n--> Missed, Try again.")
            (eq 'ENAME (type e))
            (if (_iscurveobject e)
              (LM:IntersectionLengths e)
              (princ "\n--> Invalid Object Selected.")
            t
  (princ)
(defun c:IntLenM ( / *error* ss i )
    (princ)
    (if (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE"))))
      (repeat (setq i (sslength ss))
        (LM:IntersectionLengths (ssname ss (setq i (1- i))))
  (princ)
(defun LM:IntersectionLengths
  ( e  ;; Entity name
    / *error* _startundo _endundo _groupbynum _sortbyparam _makereadable _isannotative _uniquefuzz
      a acspc c d d1 d2 da e i l ll m o ss ta to ts ur x y
   lst pnt
  (setq acdoc (cond ( acdoc ) ( (vla-get-activedocument (vlax-get-acad-object)) ))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
    (if acdoc (_EndUndo acdoc))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc))
  (defun _GroupByNum ( l n / r)
    (if l
      (cons
        (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r))
        (_GroupByNum l n)
  (defun _SortbyParam ( e l )
    (vl-sort l '(lambda ( a b ) (< (vlax-curve-getParamatPoint e a) (vlax-curve-getParamatPoint e b))))
  (defun _MakeReadable ( a )
      (lambda ( a )
        (cond
          ( (and (> a (/ pi 2)) (<= a pi))
            (- a pi)
          ( (and (> a pi) (<= a (/ (* 3 pi) 2)))
            (+ a pi)
          ( a )
      (rem a (* 2 pi))
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
  (defun _uniquefuzz ( lst fuzz )
    (if lst
      (cons (car lst)
        (_uniquefuzz
          (vl-remove-if '(lambda ( x ) (equal x (car lst) fuzz)) (cdr lst)) fuzz
  (setq ts
    (/ (getvar 'textsize)
      (if (_isAnnotative (getvar 'textstyle))
        (cond ( (getvar 'cannoscalevalue) ) ( 1.0 )) 1.0
  (_StartUndo acdoc)
  (vla-getBoundingBox (setq o (vlax-ename->vla-object e)) 'll 'ur)
  (mapcar '(lambda ( x ) (set x (vlax-safearray->list (eval x)))) '(ll ur))
  (if
    (setq l
      (_sortbyparam e
        (_uniquefuzz
          (apply 'append
            (repeat
              (setq i
                (sslength
                  (ssdel e
                    (setq ss
                      (ssget "_C" (trans ur 0 1) (trans ll 0 1) '((0 . "ARC,CIRCLE,ELLIPSE,*LINE")))
              (setq l
                (cons
                  (_groupbynum
                    (vlax-invoke o 'intersectwith
                      (vlax-ename->vla-object (ssname ss (setq i (1- i)))) acextendnone
                    3
                  l
          1e-8
    (if (not (vlax-curve-isClosed e))
      (progn
        (or
          (equal (vlax-curve-getStartParam e) (vlax-curve-getParamatPoint e (car l)) 0.001)
          (setq l (cons (vlax-curve-getStartPoint e) l))
        (or
          (equal (vlax-curve-getEndParam e) (vlax-curve-getParamatPoint e (last l)) 0.001)
          (setq l (append l (list (vlax-curve-getEndPoint e))))
      (setq c l)
    (if (vlax-curve-isClosed e)
      (setq l (list (vlax-curve-getStartPoint e)) c l)
      (setq l (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e)))
  (setq pnt (vlax-curve-getclosestpointto ent (trans (cadr sel) 1 0))
        ent (car sel))
  (foreach pt (cdr l)
    (setq lst (cons (cons (abs (- (vlax-curve-getdistatpoint ent pnt)
                            (vlax-curve-getdistatpoint ent pt)))
                          pt)
                    lst)))
  (setq l (list (car l) (cdar (vl-sort lst (function (lambda (e1 e2) (< (car e1) (car e2))))))))
  (while (cadr l) (setq x (car l) y (cadr l) l (cdr l))
    (setq m y)
 ;     (vlax-curve-getPointatDist e
;        (/ (+ (vlax-curve-getDistatPoint e y) (vlax-curve-getDistAtPoint e x)) 2.)
    (setq d
      (abs
        (- (vlax-curve-getDistatPoint e y) (vlax-curve-getDistAtPoint e x))
    (setq a
      (angle '(0. 0. 0.)
        (vlax-curve-getFirstDeriv e (vlax-curve-getParamatPoint e m))
    (setq ta (_makereadable a))
    (setq to (vla-AddText acspc (rtos d) (vlax-3D-point '(0. 0. 0.)) ts))
    (vla-put-Alignment to acAlignmentMiddleCenter)
    (vla-put-TextAlignmentPoint to (vlax-3D-point (polar m (+ ta (/ pi 2.)) (* 1.1 ts))))
    (vla-put-rotation to ta)
  (if (vlax-curve-isclosed e)
    (progn
      (if (= 1 (length c)) (setq c (append c c)))
      (setq d
          (setq d1 (vlax-curve-getDistatPoint e (car c)))
          (setq d2 (- (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) (vlax-curve-getdistatpoint e (last c))))
      (setq m
          (if (< d1 (setq da (/ (+ d1 d2) 2.)))
            (setq da (- (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) (- da d1)))
            (setq da (- da d2))
      (setq a
        (angle '(0. 0. 0.)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ "\n:: IntLen.lsp | Version 1.4 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Type \"IntLen\" or \"IntLenM\" to Invoke ::")
(princ)
;;                         End of File                        ;;
Message 3 of 8
it works, yes, but the outputs are not quite what I need. the lengths the program gives are **between** intersection points, not starting from point A going to each intersection point. If this makes sense.
Message 4 of 8
ВeekeeCZ
One more shot and the last. Not sure what program you're referring to, but this bellow (with a minor fix of above code) gives you length from the beginning of polyline. But it's possible that I've misunderstood you at all......
    (princ)
    (and
      (not
          (setq param
      param
    (while
        (cond
            t
  (princ)
;;;(defun c:IntLenM ( / *error* ss i )
;;;  (defun *error* ( msg )
;;;    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
;;;        (princ (strcat "\n** Error: " msg " **")))
;;;    (princ)
;;;  (if (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
;;;    (princ "\n--> Current Layer Locked.")
;;;    (if (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE"))))
;;;      (repeat (setq i (sslength ss))
;;;        (LM:IntersectionLengths (ssname ss (setq i (1- i))))
;;;  (princ)
  ( e  ;; Entity name
   lst pnt
    (princ)
    (if l
      (cons
        (_GroupByNum l n)
      (lambda ( a )
        (cond
            (- a pi)
            (+ a pi)
          ( a )
      (rem a (* 2 pi))
    (and
    (if lst
      (cons (car lst)
        (_uniquefuzz
  (setq ts
  (_StartUndo acdoc)
  (if
    (setq l
      (_sortbyparam e
        (_uniquefuzz
          (apply 'append
            (repeat
              (setq i
                (sslength
                  (ssdel e
                    (setq ss
              (setq l
                (cons
                  (_groupbynum
                    3
                  l
          1e-8
      (progn
        (or
        (or
      (setq c l)
  (setq ent (car sel)
	pnt (vlax-curve-getclosestpointto ent (trans (cadr sel) 1 0)))
  (foreach pt (cdr l)
                          pt)
                    lst)))
    (setq m y)
    (setq d
      (abs
    (setq a
      (angle '(0. 0. 0.)
    (progn
      (setq d
      (setq m
            (setq da (- da d2))
      (setq a
        (angle '(0. 0. 0.)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
; (princ "\n:: Type \"IntLen\" or \"IntLenM\" to Invoke ::")
(princ)
;;                         End of File                        ;;
Message 5 of 8
dbhunia
Try this......
    (princ)
    (and
      (not
          (setq param
      param
    (while
      (progn (setvar 'ERRNO 0) (setq e (car (entsel)))
        (cond
            t
  (princ)
    (princ)
  (princ)
  ( e  ;; Entity name
  (setq d1 0.0)
  (setq d2 0.0)
    (princ)
    (if l
      (cons
        (_GroupByNum l n)
      (lambda ( a )
        (cond
            (- a pi)
            (+ a pi)
          ( a )
      (rem a (* 2 pi))
    (and
    (if lst
      (cons (car lst)
        (_uniquefuzz
  (setq ts
  (_StartUndo acdoc)
  (if
    (setq l
      (_sortbyparam e
        (_uniquefuzz
          (apply 'append
            (repeat
              (setq i
                (sslength
                  (ssdel e
                    (setq ss
              (setq l
                (cons
                  (_groupbynum
                    3
                  l
          1e-8
      (progn
        (or
        (or
      (setq c l)
    (setq m
    (setq d
      (abs
    (setq a
      (angle '(0. 0. 0.)
    (setq d (+ d d1))
    (setq d1 d)
    (progn
      (setq d
      (setq m
            (setq da (- da d2))
      (setq a
        (angle '(0. 0. 0.)
      (setq d (+ d d2))
      (setq d2 d)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ)
;;                         End of File                        ;;
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 6 of 8
Thank you! This is what I was looking for!
I have one more request then I promise I'm done with this topic. Is there a way for the lengths to be rounded to the nearest 1/32"?
Message 7 of 8
dbhunia
Hi
For this.....
You can try this......(This works only for "IntLen")
    (princ)
    (and
      (not
          (setq param
      param
    (while
        (cond
            t
  (princ)
;    (princ)
;  (princ)
  ( e  ;; Entity name
  (setq dd1 0.0)
  (setq dd2 0.0)
    (princ)
    (if l
      (cons
        (_GroupByNum l n)
      (lambda ( a )
        (cond
            (- a pi)
            (+ a pi)
          ( a )
      (rem a (* 2 pi))
    (and
    (if lst
      (cons (car lst)
        (_uniquefuzz
  (setq ts
  (_StartUndo acdoc)
  (if
    (setq l
      (_sortbyparam e
        (_uniquefuzz
          (apply 'append
            (repeat
              (setq i
                (sslength
                  (ssdel e
                    (setq ss
              (setq l
                (cons
                  (_groupbynum
                    3
                  l
          1e-8
      (progn
        (or
        (or
      (setq c l)
  (setq ent (car sel)
  (if (> (distance pnt (vlax-curve-getStartPoint e)) (distance pnt (vlax-curve-getendPoint e)))
	(setq l (reverse l))
    (setq m y)
    (setq d
      (abs
    (setq a
      (angle '(0. 0. 0.)
    (setq d (+ d dd1))
    (setq dd1 d)
    (progn
      (setq d
      (setq m
            (setq da (- da d2))
      (setq a
        (angle '(0. 0. 0.)
      (setq d (+ d dd2))
      (setq dd2 d)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
(princ "\n:: Type \"IntLen\" to Invoke ::")
(princ)
;;                         End of File                        ;;
Debashis Bhunia
Message 8 of 8
dbhunia
I know you have got your solution......
But still I am writing to this post because in my last solution for the point ........
Was not right (There was some error in the code). So I am posting the corrected code......
    (princ)
    (and
      (not
          (setq param
      param
    (while
        (cond
            t
  (princ)
  ( e  ;; Entity name
      a acspc c d d1 d2 da e i l ll m o ss ta to ts ur x y dd1 dd2 sec sec_pnt
  (setq dd1 0.0)
  (setq dd2 0.0)
    (princ)
    (if l
      (cons
        (_GroupByNum l n)
      (lambda ( a )
        (cond
            (- a pi)
            (+ a pi)
          ( a )
      (rem a (* 2 pi))
    (and
    (if lst
      (cons (car lst)
        (_uniquefuzz
  (setq ts
  (_StartUndo acdoc)
  (if
    (setq l
      (_sortbyparam e
        (_uniquefuzz
          (apply 'append
            (repeat
              (setq i
                (sslength
                  (ssdel e
                    (setq ss
              (setq l
                (cons
                  (_groupbynum
                    3
                  l
          1e-8
      (progn
        (or
        (or
      (setq c l)
  (setq sec (car sel)
	sec_pnt (vlax-curve-getclosestpointto sec (trans (cadr sel) 1 0)))
  (if (> (distance sec_pnt (vlax-curve-getStartPoint e)) (distance sec_pnt (vlax-curve-getendPoint e)))
    (setq m y)
    (setq d
      (abs
    (setq a
      (angle '(0. 0. 0.)
    (setq d (+ d dd1))
    (setq dd1 d)
    (progn
      (setq d
      (setq m
            (setq da (- da d2))
      (setq a
        (angle '(0. 0. 0.)
      (setq d (+ d dd2))
      (setq dd2 d)
  (_EndUndo acdoc)
  (princ)
(vl-load-com)
(princ)
;(princ "\n:: IntLen.lsp | Version 1.4 | © Lee Mac 2011 www.lee-mac.com ::")
(princ)
;;                         End of File                        ;;
Debashis Bhunia
