Clipboard
Clipboard
WeTanks
Mentor Mentor
Clipboard
WeTanks
I need your help,
I often repeat operations like the following,
Is there a LISP that pastes the objects in the to all points in batches at one time?
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
komondormrex
check thу following. uses not the clipboard but multiple copy of a source circle object to every object of target selection set of points.
(defun c:copy_to_multiple_points (/ object_to_copy points_to_copy_to_list base_point)
	(setq object_to_copy (vlax-ename->vla-object (car (entsel "\nSelect object to multiple copy: ")))
	      base_point (vlax-3d-point (trans (getpoint "\nPick base point for copying object: ") 1 0))
	      points_to_copy_to_list (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "point")))))))
  	(foreach point points_to_copy_to_list
		(vla-move (vla-copy object_to_copy)
			  base_point
			  (vla-get-coordinates point)
WeTanks
Thank you so so much.
I am sorry I didn't explain it clearly enough.
Why should I use Clipboard,
It is because it can set the Base Point.
Can this be achieved in the previous LISP?
We.Tanks
図面一括印刷
komondormrex
sure, for single object to copy. check update above.
WeTanks
This LISP has saved me much time.
この LISP のおかげで時間を大幅に節約できました。
We.Tanks
図面一括印刷
komondormrex
your welcome) that is what a custom programming for.
