fit block in certain area
J-Rocks
Message 1 of 16
J-Rocks
Hello guys,
I am trying to fit a block in certain area based on the bounding Box ( width & Length ) of block into a certain area, I think I need to know how to get the XYZ scales of area which is the hardest part to me so far.
NOTE: I need to do the same process on other blocks and not necessarily the attached block.
Drawing attached.
Thank you.
Replies (15)
Message 2 of 16
jeltododre
This should get you started:
(defun c:foo ( / p1 p2 ob )
  (defun bboxcen ( o / mi ma )
    (vla-getboundingbox o 'mi 'ma)
    (mapcar '(lambda (x y) (/ (+ x y) 2)) (vlax-safearray->list mi)
    (vlax-safearray->list ma))
  (setq p1 (bboxcen (setq ob (vlax-ename->vla-object (car (entsel))))))
  (setq p2 (bboxcen (vlax-ename->vla-object (car (entsel)))))
  (vla-move ob p1 p2)
Message 3 of 16
J-Rocks
Why the program asks to select two objects ?
You may need to review the attached drawing.
Message 4 of 16
haper74945
First the block, then the green polyline ?
Message 5 of 16
Kent1Cooper
@J-Rocks wrote:
.... I need to know how to get the XYZ scales of area ....
This will give you the dimensions of the bounding box in all three axis directions:
(vla-getboundingbox (vlax-ename->vla-object TheEntityName) 'minpt 'maxpt)
(mapcar '- (vlax-safearray->list maxpt) (vlax-safearray->list minpt))
I was thinking in terms of the Block you want to put somewhere, but if you're talking about the size of the available area to put it in [the rectangle built from the two green edges with added red parts], in an orthogonal situation like that and with the green edges being one object, the same procedure will give you the dimensions of the area of that.  But will they always fit those conditions?
Kent Cooper, AIA
Message 6 of 16
J-Rocks
That is not the goal although the codes will not work because the coordinates have to be variant.
Message 7 of 16
J-Rocks
That is a very important point, the rotation is not all the time orthogonal but in general all cases currently are orthogonal.
Maybe select the area ( closed polyline ) then get the bounding box then set the scale factor of a block XYZ which is the hardest part for me which is how to do the calculation.
I have seen one routine by @ronjonp somewhere while searching but it did error due to divide on zero or so.
Thank you.
Message 8 of 16
Kent1Cooper
If the idea is that the column Block is sized to fit the rectangular area, I think I can imagine a way to do this, BUT it would be essential that you redefine the Block so that  1)  at scale factors of 1 in all directions it is one drawing unit square, meaning that the available area's dimensions can be used directly as scale factors in its insertion, and  2)  its insertion point has some meaningful relation to its content [preferably either at the middle or at the lower left corner].
Kent Cooper, AIA
Message 9 of 16
J-Rocks
I don't think I can play with the blocks and if its up to me then I will convert the block to dynamic and add parameters for Length x Height and this should work perfectly.
Message 10 of 16
jeltododre
You want something like this?
Select a rectangular polyline for scale first, then the block to fit inside.
Keep in mind that something in the block from your sample drawing sticks out over the edges so the x scale will be a little off. There are also too many variables to make this work correctly for all cases (rotation, what is x or y scale, etc..)
(defun c:foo ( / o1 o2 ob en x y xn yn xblock yblock anx )
  (defun bbox ( o / mi ma )
    (list (vlax-safearray->list mi) (vlax-safearray->list ma))
    (mapcar '(lambda (x y) (/ (+ x y) 2)) (vlax-safearray->list mi) (vlax-safearray->list ma))
  (setq o1 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (eq (car x) 10)) (entget (setq en (car (entsel "Select Polyline: ")))))))
  (setq x (distance (car o1) (cadr o1)))
  (setq y (distance (cadr o1) (caddr o1)))
  (setq yn (min x y))
  (setq xn (max x y))
  (cond
    ( (eq x xn)
      (setq anx (angle (car o1) (cadr o1)))
    ( t (setq anx (angle (cadr o1 (caddr o1)))))
  (setq ob (vlax-ename->vla-object (car (entsel "Select Block: "))))
  (vla-put-rotation ob 0)
  (setq o2 (bbox ob))
  (setq xblock (abs (- (caar o2) (caadr o2))))
  (setq yblock (abs (- (cadar o2) (cadr (cadr o2)))))
  (vla-put-xeffectivescalefactor ob (* (/ xn xblock) (vla-get-xeffectivescalefactor ob)))
  (vla-put-yeffectivescalefactor ob (* (/ yn yblock) (vla-get-yeffectivescalefactor ob)))
  (vla-rotate ob (bboxcen ob) anx)
  (vla-move ob (bboxcen ob) (bboxcen (vlax-ename->vla-object en)))
Message 11 of 16
J-Rocks
The code errors :
Command: foo Select Polyline: Select Block: ; error: lisp value has no coercion to VARIANT with this type: (58.8878 12.0748 0.0)
Message 12 of 16
jeltododre
Hm.. works for me. Try this modification. move and rotate probably need a variant.
  (setq yn (min x y))
  (setq xn (max x y))
  (cond
    ( (eq x xn)
    ( t (setq anx (angle (cadr o1) (caddr o1))))
  (setq o2 (bbox ob))
  (vla-rotate ob (vlax-3d-point (bboxcen ob)) anx)
  (vla-move ob (vlax-3d-point (bboxcen ob)) (vlax-3d-point (bboxcen (vlax-ename->vla-object en))))
Message 13 of 16
J-Rocks
Beautiful, thank you.
Message 14 of 16
ronjonp
@J-Rocks
If you hit this line the code will error out:
Maybe it's my OCD but you should really fix the insertion point of your block to something that makes more sense.
Message 15 of 16
marko_ribar
Here is my attempt and I think it's good one - just needed to redefine block from start...
(defun c:foooo ( / bbox bboxcen ss o1 o2 ob en x y xn yn xblock yblock an )
  (vl-load-com)
    (mapcar '(lambda ( x y ) (/ (+ x y) 2.0)) (vlax-safearray->list mi) (vlax-safearray->list ma))
  (setvar 'insunits 0)
  (setvar 'clayer "0")
  (setvar 'cecolor "ByLayer")
  (setq ss (ssadd))
  (vl-cmdf "_.rectangle" "_non" (list 0.0 0.0 0.0) "_non" (list 1.0 1.0 0.0))
  (ssadd (entlast) ss)
  (setvar 'cecolor "4")
  (vl-cmdf "_.text" "_j" "_mc" "_non" (list 0.5 0.5 0.0) 0.15 0.0 "Column")
  (setvar 'cecolor "3")
  (vl-cmdf "_.-block" "rect" "_o" "_c" "_non" (list 0.0 0.0 0.0) ss "")
  (setq o1 (mapcar 'cdr (vl-remove-if '(lambda ( x ) (/= (car x) 10)) (entget (setq en (car (entsel "Select LWPolyline: ")))))))
  (setq yn (min x y))
  (setq xn (max x y))
  (cond
    ( (and (= x xn) (= y yn))
      (setq an (angle (car o1) (cadr o1)))
    ( t (setq an (angle (cadr o1) (caddr o1)))
  (vl-cmdf "_.zoom" "_c" (list 0.5 0.5 0.0) "2.0xp")
  (vl-cmdf "_.erase" ss "")
  (vl-cmdf "_.insert" "rect" "_non" (list 0.0 0.0 0.0))
  (while (< 0 (getvar 'cmdactive))
    (vl-cmdf "")
  (setq ob (vlax-ename->vla-object (car (entsel "\nSelect Block: "))))
  (vl-cmdf "_.zoom" "_p")
  (vla-put-rotation ob 0.0)
  (vla-put-xeffectivescalefactor ob 1.0)
  (vla-put-yeffectivescalefactor ob 1.0)
  (vla-put-zeffectivescalefactor ob 1.0)
  (setq o2 (bbox ob))
  (if (and (= x xn) (= y yn))
    (progn
      (setq xblock (max (abs (- (caar o2) (caadr o2))) (abs (- (cadar o2) (cadr (cadr o2))))))
      (setq yblock (min (abs (- (caar o2) (caadr o2))) (abs (- (cadar o2) (cadr (cadr o2))))))
    (progn
      (setq xblock (min (abs (- (caar o2) (caadr o2))) (abs (- (cadar o2) (cadr (cadr o2))))))
      (setq yblock (max (abs (- (caar o2) (caadr o2))) (abs (- (cadar o2) (cadr (cadr o2))))))
  (vla-put-xscalefactor ob (* (/ xn xblock) (vla-get-xscalefactor ob)))
  (vla-put-yscalefactor ob (* (/ yn yblock) (vla-get-yscalefactor ob)))
  (vla-put-zscalefactor ob 1.0)
  (vla-rotate ob (vlax-3d-point (bboxcen ob)) an)
  (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 16 of 16
jeltododre
Oops, thanks for pointing it out Ron. It's fixed now.
Not great coding, but I guess it does do the needful.
@marko_ribar
It gets stuck in a loop for me, trying to redefine a block..
edit: Just realized you copy pasted most of my shitty code. Hilarious
