Check a drawing files date befor opening
richie_hodgson
richie_hodgson
Is there a way to check a drawings date with lisp prior to opening it
What I want to achieve is copy a file from one directory to another but only if it is a laer version.
I can do the copy with vl-filecopy and this will probably take an unnoticeable amount of time as the file will be quite small but I am interested to see if this is achievable.
Richie
dlanorh
Check the following links. The second one is about scripting file system objects and may require some deep digging using (vlax-dump-object) to find what is available.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-to-compare-quot-lsp-quot-last-m...
https://www.afralisp.net/archive/lisp/script1.htm
I am not one of the robots you're looking for
pbejse
True, That is exactly what I used. Also, look into  vl-file-systime.
Holler if you need help with this.
pBe
pbejse
Stupid me, I did not check the posted link 😄
ronjonp
You can also leverage xcopy with the '/D' switch to do this .. HERE is a link to some code that you can use within AutoCAD.
richie_hodgson
That does sound promising. I will have a play and see what I can come up with.
Richie
