Disable Autocad TEXT Window (text screen)
andkal
Message 1 of 8
andkal
Hi
Is there a way to disable textscreen that appears after (textscr) or F2 button pressed? There are some commands in my lisp routines like -dwgunits, -list, -insunits   that open that window. I would like it to stay closed becouse the same prompts I get in commandline. I close it with (graphscr) buy anyway it's annoying when it shows up for a milisecond.
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
Replies (7)
Message 2 of 8
Moshe-A
@andkal  hi,
you can do something like this, graphscr can be invoked transparently.
(command "-dwgunits" "'graphscr" 2 2 4 "n" "y") ; but still you will notice the flickering
the same for -units
for the LIST there is no 'cure' at least that i know of.
moshe
moshe
Message 3 of 8
john.uhden
How about if you get rid of the (command ...) calls and just print the values you want using (getvar)?
John F. Uhden
Message 4 of 8
andkal
Actually Insunits was not a perfect example. Sorry for that.
I ment especially -dwgunits and -list. The only method I found to retrieve some values that Autocad displayes with those commands is to create a log file and read from it.
fe.
-Drawing Units in Autocad    or
-Connection points of fittings in Autocad MEP
 In >this< thread I posted an example how to get DWG Units in such a way but Im not happy with that text window that flashes for a split of a second. I haven't found any solution for that in the internet unfortunatelly..
• Autodesk AppStore
Message 5 of 8
CodeDing
@andkal ,
To my knowledge, all items inside the "Units" dialog can be updated with a system variable..
In your case of -DWGUNITS, use LUNITS instead:
(getvar 'LUNITS)
(setvar 'LUNITS 2)
In your case of LIST, use (getpropertyvalue) or (setpropertyvalue) instead:
(progn
(setq e (car (entsel)));select a circle
(setq r (getpropertyvalue e "Radius"))
(prompt (strcat "\nOld Radius: " (rtos r)))
(setq r 2.5) (setpropertyvalue e "Radius" r)
(prompt (strcat "\nNew Radius: " (rtos r))) );progn
... I frequently use (dumpallproperties) to see all of the available properties for an entity:
(dumpallproperties (car (entsel)))
Hope this helps..
Best,
~DD
Message 6 of 8
andkal
hallo CodeDing
I normally use methods you mentioned to get preperties, but in AMEP objects not all properties are available for LISP. Hence:  -list command as a walkaround.
As for LUNITS - it doesn't define units for lenght  [inch, feet, mm, m etc]   but their format [Scientific, Decimal, Architectual and so on]
• Autodesk AppStore
Message 7 of 8
CodeDing
@andkal ,
Thank you for some clarification.
"-DWGUNITS", to my knowledge, is only a non-dialog version of the "UNITS" command, but with an option to "scale" existing items. Can you provide examples of what this command can do that changing system variables cannot do?
I do not work with AMEP objects, can you post one in a sample dwg and explain what properties you are trying to retrieve from it?
Best,
~DD
Message 8 of 8
andkal
example for AMEP >here<.
As for -DWGunits - this is the only command, that I know of, that stores information about dwaring units. If I have some drawings with different units I need to make INSUNITSDEFTARGET systemvariable dependent from Drawing Units  to paste a specific block in right dimmensions. Some drawing can have [mm] as units and INSUNITS set to [mm] and other can have [inches] as units and INSUNITS set to [mm] as well, so I need program to know it.
But it is just an example of a problem that I already solved.  Wanting the program to look better I needed to get rid of that Text Screen I asked about in my first post.
• Autodesk AppStore
