I need some help with the following routine. Been so long since I have done any lisping I don't know how to do this.
I work in decimal units and I have this routine that will change a selected text to a distance label in decimal format. I often work with contractors that work in feet and inches. We have architectural plans sometimes in where the dimensions don't mathematically add up or "close" and we need to get a dimensioned plan that does close. I am usually left in charge of this. I want to be able to show both decimal distances as well as architectural distances on one plan.
I was just going to change the lisp below but can't figure it out. What I need to do is multiply the distance stored in "b" by 12 and stored as a new value. Any help would be greatly appreciated.
or
I've tried creating a label style in C3D but can't get that figured out either. Working in decimal and wanting architecture isn't working so well for me and my limited customization skills. I will take anything that someone can throw my way. What would be awesome is a C3D label style that would give me decimal distance above the selected line with a architectural distance above that?
I can't figure it out.
Thanks for your help. This will make life for all of us on this next project much better.
(defun c:dch (/ a b c d e f g)
(setq a (getpoint "Select first point ")) (terpri)
(setq b (getdist a "Select second pt ")) (terpri)
(setq c (strcat (rtos b 4)))
(setq d (entget (car (entsel)))) (terpri)
(setq e (assoc 1 d))
(setq f (cons (car e) c))
(setq g (subst f e d))
(entmod g))
