Changing order in an rectangle dimensions and colors + insert table code
torpass
torpass
Hello everyone,
I have this lisp code and I need only one change: the order of the values ​​under "LENGHT" should be sorted in descending order, and should have priority over the other values ​​and colors.
I only need this step, but I'm having trouble. Can you help me please?
;; Tab.lsp ;;
(defun rectangle_dims (e / l a b)
  (setq l (mapcar 'cdr (vl-remove-if '(lambda (x) (/= (car x) 10)) e)))
  (if
    (and
      (or
        (= 1 (logand (cdr (assoc 70 e)) 1))
        (equal (car l) (last l) 1e-8)
      (equal (distance  (car   l) (caddr l)) (distance  (cadr   l) (cadddr l)) 1e-8)
      (equal (mapcar '- (cadr  l) (car   l)) (mapcar '- (caddr  l) (cadddr l)) 1e-8)
      (equal (mapcar '- (caddr l) (cadr  l)) (mapcar '- (cadddr l) (car    l)) 1e-8)
    (vl-sort (list (fix (distance (car l) (cadr l))) (fix (distance (cadr l) (caddr l)))) '<)
(defun C:TAB (/ *error* ss e old r p1 c)
  (vl-load-com)
  (setq acObj (vlax-get-acad-object)
        acDoc (vla-get-activedocument acObj)
        space (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'PaperSpace 'ModelSpace))
  (vla-startundomark acDoc)
  ;;;;;; Error function ;;;;;;;;;
  (defun *error* (msg)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*BREAK*"))
      (princ (strcat "\nError: " msg))
    (vla-endundomark acDoc)
    (princ)
  (if
    (setq ss (ssget '((0 . "LWPOLYLINE") (-4 . "<OR") (90 . 4) (90 . 5) (-4 . "OR>"))))
    (progn
      (repeat (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i)))
              c (cond
                  ((cdr (assoc 62 (entget e))))
                  ((cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 (entget e)))))))
              c (if (zerop c) 7 c)
        (if
          (and
            (setq dims (rectangle_dims (entget e)))
            (setq dims (cons c dims))
          (if
            (setq old (vl-some '(lambda (d) (if (equal (cdr d) dims 1e-8) d)) r))
            (setq r (subst (cons (1+ (car old)) dims) old r))
            (setq r (cons  (cons 1 dims) r))
      (if
        (and r (setq p1 (getpoint "\nSpecify table insert point: ")))
        (insert_table
          (vl-sort
            (vl-sort
              (vl-sort
                (mapcar '(lambda (a) (list (fix (cadr a)) (fix (caddr a)) (fix (cadddr a)) (car a))) r)
                '(lambda (a b) (< (caddr a) (caddr b)))
              '(lambda (a b) (< (cadr a) (cadr b)))
            '(lambda (a b) (< (car a) (car b)))
          p1
  (princ)
;;The textheight in table depends on cannonscale
(defun insert_table (lst pct / tab row col ht i n acol)
  (setq ht  (/ 2.5 (getvar 'cannoscalevalue))
        pct (trans pct 1 0)
        n   (trans '(1 0 0) 1 0 T)
        tab (setq tab (vla-addtable space (vlax-3d-point pct) (+ 3 (length lst)) 3 (* 1.5 ht) ht))
        acol (vla-getinterfaceobject acobj  (strcat "AutoCAD.AcCmColor." (substr (vla-get-version acobj) 1 2)))
  (vlax-put tab 'direction n)
  (vla-mergecells tab 1 1 0 2)
  (mapcar
    (function
      (lambda (rowType)
        (vla-SetTextStyle  tab rowType (getvar 'textstyle))
        (vla-SetTextHeight tab rowType ht)
   '(2 4 1)
  (vla-put-HorzCellMargin tab (* 0.14 ht))
  (vla-put-VertCellMargin tab (* 0.14 ht))
  (setq lst (cons '(nil "SECTION" "LENGHT" "PCS") lst))
  (setq lst (mapcar '(lambda (el) (list (car el) (last el) (cadr el) (caddr el))) lst))
  (setq lst (cons '(nil "sp:" nil nil) lst))
  (setq i 0)
  (foreach col (apply 'mapcar (cons 'list (mapcar 'cdr lst)))
    (vla-SetColumnWidth tab i
      (apply
        'max
        (mapcar
          '(lambda (x)
             ((lambda (txb) (+ (abs (- (caadr txb) (caar txb))) (* 2.0 ht)))
              (textbox (list (cons 1 (vl-princ-to-string x)) (cons 7 (getvar 'textstyle)) (cons 40 ht)))
          col
    (setq i (1+ i))
  (setq lst (cons '(nil "XX") lst))
  (setq row 0)
  (foreach r lst
    (setq col 0)
    (vla-SetRowHeight tab row (* 1.5 ht))
    (foreach c (cdr r)
      (vla-SetText tab row col (vl-princ-to-string c))
      (if
        (car r)
        (progn
          (if (/= (vla-get-colorindex acol) (car r)) (vla-put-colorindex acol (car r)))
          (vla-SetCellContentColor tab row col acol)
      (setq col (1+ col))
    (setq row (1+ row))
(princ "\nType TAB to start the command")
paullimapa
change the following section of the code from:
          (vl-sort
            (vl-sort
              (vl-sort
To this:
(vl-sort
            (vl-sort
              (vl-sort
            '(lambda (a b) (> (caddr a) (caddr b)))
Paul Li
IT Specialist
@The Office
torpass
Thank you, bur unfortunetly it dosen't work on Autocad LT, how is that possible? Are there solutions?
paullimapa
LT lisp doesn’t support this function
which is used to get the color.
you can read the LT lisp limitations here
Paul Li
IT Specialist
@The Office
komondormrex
change line 89
from that
to this
acol (vla-getcellcontentcolor tab 0 0)
