Changes to Leader Settings
kpennell
Message 1 of 13
kpennell
I've done a lot of searching, and testing, from this forum, for a good solid few hours, and can't seem to get what I want to stick.
I'm trying, at the command prompt of course, change a leader setting, to use MText (currently 'none' is enabled), and when Mtext is enabled, to NOT prompt for width.
Of all the sample code that I've used, whatever variables I change in the code, don't seem to stick.  When I open the qleader settings window, nothing has changed.
Any takers.  thanks so much in advance.
KP
Replies (12)
Message 2 of 13
devitg
Would you, please , upload the sample dwg and what do yo didi in Lisp?
Message 3 of 13
ВeekeeCZ
Complicated but possible. Load THIS routine and run this
(acet-ql-set '((60 . 0)(68 . 0)))
before you initially run the qleader command.
Read the routine's description for more details.
Message 4 of 13
kpennell
Regardless of what I use in the '(acet-ql-set '((60 . 4)(68 . 0)))' makes no difference to the 'settings' window for the 'qleader' command.
Stumped.
Message 5 of 13
ВeekeeCZ
Not sure if I put the pressure on the right words... so do the following in order:
- turn off AutoCAD
- turn on AutoCAD
- load the routine
- run the set-up function
- run QLEADER
That way it works for me.
Message 6 of 13
kpennell
Man, I don't know what I'm doing wrong to be honest.  I've uploaded a video of what I'm doing.  According to your instructions, it should be working.
Message 7 of 13
ВeekeeCZ
You run the Qleader command BEFORE you applied the initial setting by the routine. Don't.
The correct workflow:
Open a new drawing, don't run the QLeader here,  load the routine, run the function, run the QLeader command
I've made the VIDEO for you too - demonstrated this many times successfully. Note that my default setting is actually "Mtext", so I changed a setting by the routine to "none".
Message 8 of 13
kpennell
Wild. I can certainly this being successful for you.  I'm running 2016, but I'd doubt that makes a difference.
Message 9 of 13
kpennell
So when I use '(acet-ql-set '((3 . "ClosedBlank")(40 . 0.0)(60 . 4)))' it changes the arrow head for me just fine, but it's totally ignoring the (60 . 4) dotted pair.
Message 10 of 13
ВeekeeCZ
Hm, you got me. When I changed the template to none I was unable to change it back to MTEXT by the routine.
I suggest you change the template to default MTEXT too if possible.
Or move to MLEADERs like most of the people. It has its benefits.
Message 11 of 13
kpennell
Just found out my issue.
The acet-ql-set will work if the 'qleader' command has never been invoked.  Works on a fresh brand new drawing.
So now the question is, if I want a lisp to change the leader settings as I develop a drawing, how would one do that through lisp?
Message 12 of 13
kpennell
I have since figured out that it has to do with the 'dbmod' variable.  When retrieving the value of the 'dbmod' system variable and it's 0, 1, 4 or 5, the code will work.
when I save my drawing, the 'dbmod' value returns to '0', and the code works great.
Message 13 of 13
kpennell
I'm stuck again.  The modification to the qleader settings do not take effect if the drawing is already in progress, even after a save, to bring the 'dbmod' variable to '0'. Tearing my hair out here.
