Fix Lisp Routine to allow it work with Dynamic Block
jtm2020hyo
Message 1 of 8
jtm2020hyo
I Attached a LISP routine (attach 1 named BBL1) create a polyline between selected name block and him nearest block. have 2 options: link selected name block with another selected or link with a block that has a certain layer.
the problem is that this lisp does not work with the blocks that I need to work. (drawing ATTACHED 2 named "test1")
probably is because are Dynamic Block.
anyone can help me?
Accepted solutions (4)
Replies (7)
Message 2 of 8
dbhunia
Hi
anyone can help me?
There is no attachment in this post.....
Another thing if you are using the code from your post......
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/modify-lisp-to-work-only-at-certain-...
Then the code is working fine (with Dynamic Block also) in your attached Drawing......
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 8
jtm2020hyo
I have need a lot of thing to do with this lisp. each post should add a new feature to this lisp. I hope I'm doing it right.
@dbhunia wrote:
Hi
anyone can help me?
Maybe was a error. In this reply I will attach lisp routine.
Message 4 of 8
dlanorh
Try the attached. I've reworked your lisp and added sub-routines to get dynamic block names, filter selection sets and make coordinate lists.
I am not one of the robots you're looking for
Message 5 of 8
dbhunia
Hi
Try this......
Debashis Bhunia
Message 6 of 8
dlanorh
Just noticed a glaring comparison error. Attached it corrected lisp.
Message 7 of 8
jtm2020hyo
Thanks for their help. both are pretty smart.
@dlanorh @dbhunia
Message 8 of 8
dlanorh
Found another error. Updated code attached.
