change the text value from string
avinash00002002
avinash00002002
Hi!
I have some strings which has space in left , middle , and right side and there is not equal space every time.
like...
" 2311 51"
" 51 2552"
" 51 2612"
" 153 51"
I want to change its value by +50. any idea how to do.
Avinash
hak_vz
Here you have some functions to use.
Check how this function work and combine to your code. Since you are learning to code in lisp
this is good exercise for you.
(defun rem1 (str) (vl-string-trim " " str))
(defun rem2 (str / str)
 (while (vl-string-search "  " str)
	(setq str (vl-string-subst " " "  " str))
	(setq str (vl-string-subst "," " " str))
(defun str_to_lst (str /  lst pos )
    (while (setq pos (vl-string-search "," str))
        (setq lst (cons (substr str 1 pos) lst)
              str (substr str (+ pos (1+ (strlen ","))))
    (reverse (cons str lst))
(defun string_to_list ( str del / pos )
	(if (setq pos (vl-string-search del str))
		(cons (substr str 1 pos) (string_to_list (substr str (+ pos 1 (strlen del))) del))
		(list str)
Also
(vl-string-left-trim " 2311 51" " ")
Miljenko Hatlak
CADaSchtroumpf
(defun vl-position-multi (el l / n l_id l_n)
	(setq
		n 0
		l_id (mapcar '(lambda (x) (equal x el)) l)
	(repeat (length l_id)
		(if (car l_id) (setq l_n (cons n l_n)))
		(setq n (1+ n) l_id (cdr l_id))
	(reverse l_n)
(defun foo (str / l_cv l_pos nw_val)
	(setq
		l_cv (vl-string->list str)
		l_pos (vl-position-multi 32 l_cv)
		nw_val (itoa (+ 50 (atoi (vl-list->string (vl-remove 32 l_cv)))))
	(foreach n l_pos
		(setq nw_val (vl-string-subst (strcat " " (substr nw_val (1+ n) 1)) (substr nw_val (1+ n) 1) nw_val n))
	nw_val
Command: (foo " 2311 51")
" 2312 01"
Command: (foo " 51 2552")
" 51 2602"
Command: (foo " 51 2612")
" 51 2662"
Command: (foo " 153 51")
" 154 01"
Kent1Cooper
The usage examples in Message 3 raise the question:  What is "it" that you want to increase by 50?  The entire string as if the space were a decimal point?  If so, do you really want to increase it by 0.50, or should it be as if the space were not there, rather than a decimal point?  Or do you want to increase just the part after the space, or maybe the part before the space?  In other words, should " 2311 51" be increased to " 2312 01" as in Message 3's result, or to " 2311 101", or maybe " 2361 51", or something else?
Kent Cooper, AIA
3wood
You can also try ALTEXT.
It works in all scenario except there is only one number after the space.
Sea-Haven
My $0.05 you can change the delimeter by thinking this way.
; thanks to Lee-mac for this defun
; www.lee-mac.com
; 44 is comma 32 is space 59 is semicolon
(defun _csv->lst ( strtxt / pos )
	(if (setq pos (vl-string-position 32 strtxt))
		(cons (substr strtxt 1 pos) (_csv->lst (substr strtxt (+ pos 2))))
		(list strtxt)
