Delete from the top left to the bottom right
bschristhian
bschristhian
Hello, how are you? I had a small query, I would like to know if you could fly from the upper left and reach the lower right element by element, this is an idea, the truth is I don't know if it were possible and if so I would like a little guidance what should i do
john.uhden
@bschristhian
I don't know your purpose, but it seems to me that you have upper things and left things and lower things and right things, but it's a matter of perception only as to what is upper-left and what is lower-right.  We all know what UL and LR are for a boundingbox because it's a rectangle, but your figure is multilateral.  I can be of no help without explanation of your goal.
John F. Uhden
Kent1Cooper
@john.uhden wrote:
....  We all know what UL and LR are for a boundingbox because it's a rectangle....
But even there, suppose it is a simple rectangle you want to do this to.  Which edge is the "first" one in a series from upper left to lower right -- the top edge or the left edge?
Also, @bschristhian, what is the anticipated procedure?  Invoke the command, and presumably select the objects [apparently Lines in your image], and then what?  Does the first one [however that is determined] get Erased immediately?  Whether or not that happens first, do you then want to press something [likely Enter?] to take out the next one, repeatedly as far as you want to go?  Assuming you won't want to go all the way to removing all of them [because in that case, what does the order matter?], how would you want to end it?  Etc., etc.
Kent Cooper, AIA
bschristhian
Thank you very much for the answers it is true what I want to do is erase from upper left to lower right, I think that being able to do this is more complex than it seems
john.uhden
The solution may be to figure out what you want to keep and delete the rest.
John F. Uhden
