Change the attributes of autocad dxf file
We are developing a software in which we have a common design, what i want is to copy the design and change size of the objects in it like line length, rectangle size etc. programatically. Can you help me out how can i do it?
cadffm
your knowledge about DXF files is?
You wrote nothing about that, so it is zero?
Which API do you want to use? .NET? C++?
Do want to write your own function library or do you want to use other existing librarys?
Here are forums/boards specially for .Net for example, search for it and ask there.
It sounds it is a hard start for you
Sebastian
Sea-Haven
1: Check out "Forge" by Autodesk allows for remote design.
2: Changing objects explain more !
