I have a topographic map with contour labels in text format. I want to change them to mtext individually without changing their location. I have a lisp routine that lets me change them individually, but the text won't stay in the same place after it converts it.
I have tried various combinations of justification before converting them using the justifytext command. The lisp that I use changes them to be justified top center, so before I convert them, I've tried to set the text to top center so that it would be the same justification as it would after the conversion, but apparently the lisp uses some other method of determining the final position.
Has anyone had this situation and has anyone found a solution?
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
