Change text angle of a multileader........
doni49
Mentor Mentor
doni49
All the links I've found indicate that the text angle is stored in bit 50.  But when I check my multileader, bit 50 isn't even set (the angle is currently set to 90 degrees).  Ninety degrees converts to 1.5708 radians.  That value is stored in bit 42.  But when I try to use entmod to change it, all that happens is the entity data (as shown below) is shown and the text is NOT rotated.
(setq ent (entget(ssname ents 0)))
((-1 . <Entity name: 16f9fe69ea0>) (0 . "MULTILEADER") (330 . <Entity name: 16f9fef39f0>) (5 . "A22A") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "R-IMG") (100 . "AcDbMLeader") (270 . 2) (300 . "CONTEXT_DATA{") (40 . 1.0) (10 -22.6058 -11.7107 0.0) (41 . 0.18) (140 . 0.18) (145 . 0.09) (174 . 1) (175 . 6) (176 . 0) (177 . 0) (290 . 1) (304 . "ASDFASDF") (11 0.0 0.0 1.0) (340 . <Entity name: 16f9fef3910>) (12 -22.6958 -11.6207 0.0) (13 6.12323e-17 1.0 0.0) (42 . 1.5708) (43 . 0.0) (44 . 0.0) (45 . 1.0) (170 . 1) (90 . -1073741824) (171 . 1) (172 . 5) (91 . -1073741824) (141 . 0.0) (92 . 0) (291 . 0) (292 . 0) (173 . 0) (293 . 0) (142 . 0.0) (143 . 0.0) (294 . 0) (295 . 0) (296 . 0) (110 -23.2629 -13.3666 0.0) (111 6.12323e-17 1.0 0.0) (112 -1.0 6.12323e-17 0.0) (297 . 0) (302 . "LEADER{") (290 . 1) (291 . 1) (10 -22.6058 -12.0707 0.0) (11 6.12323e-17 1.0 0.0) (90 . 0) (40 . 0.36) (304 . "LEADER_LINE{") (10 -23.2629 -13.3666 0.0) (91 . 0) (170 . 1) (92 . -1056964608) (340 . <Entity name: 0>) (171 . -2) (40 . 0.0) (341 . <Entity name: 0>) (93 . 0) (305 . "}") (271 . 0) (303 . "}") (272 . 9) (273 . 9) (301 . "}") (340 . <Entity name: 16f9fee1b20>) (90 . 279552) (170 . 1) (91 . -1056964608) (341 . <Entity name: 16f9fef3940>) (171 . -2) (290 . 1) (291 . 1) (41 . 0.36) (42 . 0.18) (172 . 2) (343 . <Entity name: 16f9fef3910>) (173 . 1) (95 . 6) (174 . 1) (175 . 0) (92 . -1056964608) (292 . 0) (93 . -1056964608) (10 1.0 1.0 1.0) (43 . 0.0) (176 . 0) (293 . 0) (294 . 0) (178 . 0) (179 . 1) (45 . 1.0) (271 . 0) (272 . 9) (273 . 9) (295 . 1))
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
pendean
Community Legend
Community Legend
@doni49 Can you share a screenshot of what the final result is meant to be? Just explode an MLEADER then fudge it for us to see your intent.
BlackBox_
DXF 50 refers to the oblique angle of the text style, which is in the DXF 340 subentity definition.
The oblique angle of the MText is part of the TextString property value itself... as example, this MLeader MText has a 45-degree oblique angle:
"{\\Q45;Your MLeader Text Here}"
HTH
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
ВeekeeCZ
Help says it's 42.
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-EC56D0DE-026D-46AB-87B1-9692393B0C22
But if your goal is to change it... I would rather use the setproperty..
(setpropertyvalue (car (entsel)) "MText/Rotation" 0)
Sea-Haven
If I understand correctly change angle of Text.
(setq obj (vlax-ename->vla-object (car (entsel "\nPick mleader object "))))
(vlax-put obj 'textrotation (/ pi 2)) ; 90 degrees angle is in radians.
komondormrex
@doni49
it seems the group 42 is rather informative, while the group 13 holds cosine and sine values of the angle of rotation of the text of a multileader.
check the following.
(defun c:change_ml_text_angle ()
  (setq ml_text_rotation_angle (/ (* pi (getreal "\nEnter Mleader Text rotation angle in decimal degrees: ")) 180))
  (setq ml_ename_dxf (entget (car (entsel "\nPick Mleader to change text rotation: "))))
  (entmod (subst (list 13 (cos ml_text_rotation_angle) (sin ml_text_rotation_angle)) (assoc 13 ml_ename_dxf) ml_ename_dxf))
oops, not that simple)
