Change text angle of a multileader........
- Mute
- Permalink
- Report
All the links I've found indicate that the text angle is stored in bit 50. But when I check my multileader, bit 50 isn't even set (the angle is currently set to 90 degrees). Ninety degrees converts to 1.5708 radians. That value is stored in bit 42. But when I try to use entmod to change it, all that happens is the entity data (as shown below) is shown and the text is NOT rotated.
(setq ent (entget(ssname ents 0)))
((-1 . <Entity name: 16f9fe69ea0>) (0 . "MULTILEADER") (330 . <Entity name: 16f9fef39f0>) (5 . "A22A") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "R-IMG") (100 . "AcDbMLeader") (270 . 2) (300 . "CONTEXT_DATA{") (40 . 1.0) (10 -22.6058 -11.7107 0.0) (41 . 0.18) (140 . 0.18) (145 . 0.09) (174 . 1) (175 . 6) (176 . 0) (177 . 0) (290 . 1) (304 . "ASDFASDF") (11 0.0 0.0 1.0) (340 . <Entity name: 16f9fef3910>) (12 -22.6958 -11.6207 0.0) (13 6.12323e-17 1.0 0.0) (42 . 1.5708) (43 . 0.0) (44 . 0.0) (45 . 1.0) (170 . 1) (90 . -1073741824) (171 . 1) (172 . 5) (91 . -1073741824) (141 . 0.0) (92 . 0) (291 . 0) (292 . 0) (173 . 0) (293 . 0) (142 . 0.0) (143 . 0.0) (294 . 0) (295 . 0) (296 . 0) (110 -23.2629 -13.3666 0.0) (111 6.12323e-17 1.0 0.0) (112 -1.0 6.12323e-17 0.0) (297 . 0) (302 . "LEADER{") (290 . 1) (291 . 1) (10 -22.6058 -12.0707 0.0) (11 6.12323e-17 1.0 0.0) (90 . 0) (40 . 0.36) (304 . "LEADER_LINE{") (10 -23.2629 -13.3666 0.0) (91 . 0) (170 . 1) (92 . -1056964608) (340 . <Entity name: 0>) (171 . -2) (40 . 0.0) (341 . <Entity name: 0>) (93 . 0) (305 . "}") (271 . 0) (303 . "}") (272 . 9) (273 . 9) (301 . "}") (340 . <Entity name: 16f9fee1b20>) (90 . 279552) (170 . 1) (91 . -1056964608) (341 . <Entity name: 16f9fef3940>) (171 . -2) (290 . 1) (291 . 1) (41 . 0.36) (42 . 0.18) (172 . 2) (343 . <Entity name: 16f9fef3910>) (173 . 1) (95 . 6) (174 . 1) (175 . 0) (92 . -1056964608) (292 . 0) (93 . -1056964608) (10 1.0 1.0 1.0) (43 . 0.0) (176 . 0) (293 . 0) (294 . 0) (178 . 0) (179 . 1) (45 . 1.0) (271 . 0) (272 . 9) (273 . 9) (295 . 1))
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
