Change only selected Attribute
C.Utzinger
Message 1 of 12
C.Utzinger
Hi
I have the following code.
It would be great when I Pick an existing Block (entsel) to change only one Attribute (the slected one) and not have to go through every Attribute again.
Is that possible? Thanks for help!
(vl-load-com)
(defun C:<Test2 ( / *error* oATTREQ oATTDIA LM:vl-setattributevalue :roundUpToTens ent ANZAHL HÖHE LÄNGE DECKE)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
         (setvar 'ATTREQ oATTREQ)
         (setvar 'ATTDIA oATTDIA)
    	 (command-s "_.undo" "_end")
    (princ))
  (defun LM:vl-setattributevalue ( blk tag val )
    (setq tag (strcase tag))
    (vl-some '(lambda ( att )
                (if (= tag (strcase (vla-get-tagstring att)))
                  (progn (vla-put-textstring att val) val)))
             (vlax-invoke blk 'getattributes)))
  (defun :roundUpToTens (x / ) (* (atoi (rtos (+ (* x 0.1) 0.49) 2 0)) 10))
  (command "_.undo" "_begin")
  (setq oATTREQ (getvar 'ATTREQ)
        oATTDIA (getvar 'ATTDIA))
  (setvar 'ATTREQ 0)
  (setvar 'ATTDIA 0)
  (if (not KUFU)(setq KUFU "mit"))
  (setq ANZAHL 10)
  (setq HÖHE 20)
  (setq DECKE 25)
 (if (setq ent (car (entsel "\nDistanzkorbtext wählen oder <Neuer einfügen>: ")))
      (progn
	 (initget "Mit Ohne")
	 (setq KUFU (cond ((getkword (strcat "\nMit oder ohne KUFU (mit/ ohne) <" KUFU ">: ")))(KUFU)))
	 (setq KUFU (strcase KUFU T))
	 (initget 6)
	 (setq ANZAHL (:roundUpToTens (cond ((getint (strcat "\nAnzahl Körbe <" (itoa ANZAHL) ">: ")))(ANZAHL))))
	 (initget 6)
	 (setq HÖHE (cond ((getint (strcat "\nHöhe der Körbe <" (itoa HÖHE) ">: ")))(HÖHE)))
	 (setq LÄNGE (* ANZAHL 2.5))
	 (initget 6)
	 (setq DECKE (strcat "für Decke d=" (itoa (cond ((getint (strcat "\nDeckenstärke <" (itoa DECKE) ">: ")))(DECKE))) " cm"))
      	 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "KUFU" (strcat "DK " KUFU " KUFU"))
     	 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "ANZAHL" ANZAHL)
         (LM:vl-setattributevalue (vlax-ename->vla-object ent) "HÖHE" HÖHE)
     	 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "LÄNGE" LÄNGE)
    	 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "DECKE" DECKE)
      (progn
  	(if (and (not (command "_.INSERT" "spi-bew-dkm_test" "_s" 1 "_r" 0))
           (princ "\nIn Eisenliste bei Distanzkörbe einfügen: \n")
           (not (command PAUSE))
           (setq ent (entlast))
	   (progn
	   (initget 6)
	   (initget 6)
	   (initget 6)
	   (setq DECKE (strcat "für Decke d=" (itoa (cond ((getint (strcat "\nDeckenstärke <" (itoa DECKE) ">: ")))(DECKE))) " cm")))
    	(progn
           (LM:vl-setattributevalue (vlax-ename->vla-object ent) "DECKE" DECKE)))))
  (command "_.undo" "_end")
  (prin1)
) ; end of defun
Replies (11)
Message 2 of 12
cadffm
"It would be great when I Pick an existing Block (entsel) to change only one Attribute (the slected one) "
But you dont have "selected one Attribute" with entsel, Select nested Objects with Nentsel (F1) !
(setq a (nentsel))
(alert  (vl-princ-to-string (entget(car a))))
Sebastian
Message 3 of 12
C.Utzinger
Sorry but I don't know how to introduce that in my code :(...
Message 4 of 12
ВeekeeCZ
Keep the standardized selectable prompts.
(setq KUFU (cond ((getkword (strcat "\nMit oder ohne KUFU [Mit/Ohne] <" KUFU ">: "))) (KUFU)))
Message 5 of 12
SeeMSixty7
Here is something I wrote back in 89 and it works great still. I tis nothing fancy in anyway, but works just fine.
Good luck,
by: Clint Moore
Date:11-10-89
(defun c:ac (/ old )
  (setq old AC_VAL)
  (if old
    (setq AC_VAL (getstring T (strcat "\nEnter new value:<" old ">:")))
    (setq AC_VAL (getstring T "\nEnter new value: "))
  (if (= AC_VAL "")
   (setq AC_VAL old)
  (prompt "\nSelect Attribute: ")
  (command "attedit" "" "" "" "" pause "" "v" "" AC_VAL "")
  (princ)
Message 6 of 12
C.Utzinger
I'm getting crazy.
I'm testing with the LeMac functions, but i'm getting nowhere.
How can I after nentsel get the Attribute tag.
Please help...
Message 7 of 12
ВeekeeCZ
Get entity's definition list: (entget (car (nentsel)))
Then see what entity you have -> ATTRIB
Use HELP, search for "ATTRIB dxf"
See code 2?
then as usual
(cdr (assoc 2 (entget (car (nentsel)))))
Message 8 of 12
C.Utzinger
Thank you
I was not so far away, but lost...:)
Kind regards
Message 9 of 12
SeeMSixty7
Here is a quick sample for you to see how to use it.
Good luck,
(defun c:QCHG()
	(setq mynewvalue "NEWVALUE"
		  myattent (nentsel "\nSelect Attribute to change: ")
	(if myattent
		(progn
			(setq myattdata (entget (car myattent))
				  oldvalue (assoc 1 myattdata)
				  newvalue (cons 1 mynewvalue)
				  myattdata (subst newvalue oldvalue myattdata)
			(entmod myattdata)
			(entupd (cdr (assoc 330 myattdata)))
Message 10 of 12
C.Utzinger
HI
I have my code now like this:
I found no way to select the block once. Is there a possibility to do that?
(vl-load-com)
(defun C:<Test7 ( / *error* oATTREQ oATTDIA LM:vl-setattributevalue :roundUpToTens ent ent2 ANZAHL HÖHE LÄNGE DECKE)
    (princ))
  (setvar 'ATTREQ 0)
  (setvar 'ATTDIA 0)
  (setq ANZAHL 10)
  (setq HÖHE 20)
  (setq DECKE 25)
      (progn
	 (setq ent2 (cdr (assoc 2 (entget (car (nentsel "\nZu ändernden Text wählen:"))))))
	 (cond ((= ent2 "KUFU")(progn
				 (initget 1 "Mit Ohne")
	 			 (setq KUFU (getkword "\nMit oder ohne KUFU (mit/ ohne): "))
				 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "KUFU" (strcat "DK " KUFU " KUFU"))))
	       ((= ent2 "ANZAHL")(progn
				   (initget 7)
	 			   (setq ANZAHL (:roundUpToTens (getint "\nAnzahl Körbe: ")))
				   (LM:vl-setattributevalue (vlax-ename->vla-object ent) "ANZAHL" ANZAHL)))
	       ((= ent2 "HÖHE")(progn
			         (initget 7)
	 			 (setq HÖHE (getint "\nHöhe der Körbe: "))
				 (LM:vl-setattributevalue (vlax-ename->vla-object ent) "HÖHE" HÖHE)))
	       ((= ent2 "LÄNGE")(alert "Die Länge wird durch die Anzahl Körbe automatisch bestimmt."))
	       ((= ent2 "DECKE")(progn
				 (initget 7)
	 			 (setq DECKE (strcat "für Decke d=" (itoa (getint "\nDeckenstärke: ")) " cm"))
      (progn
	   (progn
	        (setq KUFU (cond ((getkword (strcat "\nMit oder ohne KUFU [Mit/ Ohne] <" KUFU ">: ")))(KUFU)))
	   (initget 6)
	   (initget 6)
	   (initget 6)
    	(progn
  (prin1)
) ; end of defun
Message 11 of 12
ВeekeeCZ
Besides you have the answer right in front of your eyes,
... sometimes is useful the (nentselp) function to re-select the same point again.
(and (setq ensel (entsel "\nSelect attribute to change: "))
     (setq atten (car (nentselp (cadr ensel))))
Message 12 of 12
C.Utzinger
Good morning
Thank you, I have it now like this and it works!
(if (and (setq ensel (entsel "\nDistanzkorb-Text wählen oder <Neuer einfügen>: "))
     	 (setq ent (car ensel))
     	 (setq ent2 (cdr (assoc 2 (entget (car (nentselp (cadr ensel))))))))
Kind regards
