Count Attributes of specific Blocks
HI
What I Need:
Look for specifics Blocks and Mleader with Block.
Check the Attribute Pos. (type of element for example 12B) and count how many lengths there are for this Pos.
Then create a table with this Information:
Pos. 83cm 125cm
12B 30 26
19 12 14
I have 6 Blocks: Mleader with length 83+125cm / Mleader with only 83cm / Mleader with only 125cm / Text 83+125cm / Text only 83cm / Text only 125cm.
The following code is working in this direction, but still does not what i want.
Please help me with it :)...
(vl-load-com) (defun c:COUNTATT (/ acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col column colwidth datalist en headers pt row ss swap tabledata tags total txtheight widths x) ;; Lee Mac ;; http://www.lee-mac.com/attributefunctions.html (defun LM:vl-getattributes ( blk ) (mapcar '(lambda (att) (cons (vla-get-tagstring att) (vla-get-textstring att))) (vlax-invoke blk 'getattributes))) ;; Lee Mac ;; https://www.theswamp.org/index.php?topic=46547.0 (defun LM:vl-getmleaderatts ( obj / rtn ) (if (and (= "AcDbMLeader" (vla-get-objectname obj)) (= acblockcontent (vla-get-contenttype obj))) (vlax-for sub (vla-item (vla-get-blocks (vla-get-document obj)) (vla-get-contentblockname obj)) (if (= "AcDbAttributeDefinition" (vla-get-objectname sub)) (setq rtn (cons (cons (vla-get-tagstring sub) (vla-getblockattributevalue obj (LM:objectid sub))) rtn))))) (reverse rtn)) ;; ObjectID - Lee Mac ;; Returns a string containing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:objectid ( obj ) (eval (list 'defun 'LM:objectid '(obj) (if (and (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*") (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)) (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false) '(itoa (vla-get-objectid obj))))) (LM:objectid obj)) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc)) (defun sum-and-groupby-three (lst / groups res sum tmp) (while lst (setq tmp (car lst) sum (apply '+ (mapcar 'atoi (mapcar 'cdadr (setq res (vl-remove-if-not '(lambda (a) (and (eq (cdr (nth 0 a)) (cdr (nth 0 tmp))) (eq (cdr (nth 1 a)) (cdr (nth 1 tmp))) (eq (cdr (nth 2 a)) (cdr (nth 2 tmp))))) lst))))) groups (cons (subst (cons "QTY" (itoa sum))(cadr tmp) tmp) groups) lst (vl-remove-if '(lambda (a) (member a res)) lst))) (reverse groups)) ; ---------------------------------------------------------------------------------------------------------------------------- ; ---------------------------------------------------------------------------------------------------------------------------- (if (setq ss (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "INSERT") (66 . 1) (-4 . "AND>") (0 . "MULTILEADER") (-4 . "OR>")))) (progn (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) tabledata (cons (if (= "AcDbMLeader" (vla-get-objectname obj)) (LM:vl-getmleaderatts obj) (LM:vl-getattributes obj)) tabledata))) (print tabledata) (setq headers (mapcar 'car (car tabledata)) tags headers tabledata (sum-and-groupby-three tabledata) tabledata (mapcar '(lambda (x) (mapcar 'cdr x)) tabledata)) ;; sort by "A1" : (setq tabledata (vl-sort tabledata '(lambda (a b)(< (car a)(car b))))) (setq total 0) (foreach i datalist (setq total (+ total (cdr i)))) (initget 6) (setq txtheight (cond ((getreal "\nSpecify Text height for the table <50>: ")) (50))) ;<-- text height as for as in your drawing (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object))))) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc)))) (setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa (atoi (getvar "acadver")))))) (setq pt (getpoint "\nSpecify table location:") atable (vla-addtable acsp (vlax-3d-point pt) (+ 2 (length tabledata)) (length headers) (* txtheight 1.2) (* txtheight 20))) (vla-put-regeneratetablesuppressed atable :vlax-true) ;; calculate column widths : (setq swap (append (list headers) tabledata) widths nil) (while (car swap) (setq column (mapcar 'car swap) colwidth (* 1.2 (apply 'max (mapcar 'strlen column)) txtheight) widths (cons colwidth widths) swap (mapcar 'cdr swap))) (setq widths (reverse widths)) ;; set column widths (setq col 0) (foreach wid widths (vla-setcolumnwidth atable col wid) (setq col (1+ col))) (vla-put-horzcellmargin atable (* txtheight 0.5)) (vla-put-vertcellmargin atable (* txtheight 0.3)) (vla-setTextheight atable 1 txtheight) (vla-setTextheight atable 2 txtheight) (vla-setTextheight atable 4 txtheight) (vla-setText atable 0 0 "ATTRIBUTE SUMMARY") (vla-SetCellAlignment atable 0 0 acMiddleCenter) (vla-put-colorindex accol 2) (vla-setcellcontentcolor atable 0 0 accol) (setq col -1) (foreach descr headers (vla-setText atable 1 (setq col (1+ col)) descr) (vla-SetCellAlignment atable 1 col acMiddleCenter) (vla-setcellcontentcolor atable 1 col accol)) (vla-put-colorindex accol 4) (setq row 2) (foreach record tabledata (setq col 0) (foreach item record (vla-setText atable row col item) (if (= 1 col) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-SetCellAlignment atable row col acMiddleLeft)) (vla-setcellcontentcolor atable row col accol) (setq col (1+ col))) (setq row (1+ row))) (vla-put-width atable (apply '+ widths)) (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight)) (vla-put-regeneratetablesuppressed atable :vlax-false))) (if accol (vlax-release-object accol)) (if acapp (vlax-release-object acapp)) (princ) ) (prompt "\n\t---\tStart command with COUNTATT\t---\n") (princ)
