Count Attributes of specific Blocks
C.Utzinger
C.Utzinger
HI
What I Need:
Look for specifics Blocks and Mleader with Block.
Check the Attribute Pos. (type of element for example 12B) and count how many lengths there are for this Pos.
Then create a table with this Information:
Pos.     83cm   125cm
12B      30        26
19        12        14
I have 6 Blocks: Mleader with length 83+125cm / Mleader with only 83cm / Mleader with only 125cm / Text 83+125cm / Text only 83cm / Text only 125cm.
The following code is working in this direction, but still does not what i want.
Please help me with it :)...
(vl-load-com)
(defun c:COUNTATT (/ acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col
		   column colwidth  datalist en headers pt row ss swap  tabledata tags total txtheight widths x)
  ;; Lee Mac
  ;; http://www.lee-mac.com/attributefunctions.html
  (defun LM:vl-getattributes ( blk )
    (mapcar '(lambda (att) (cons (vla-get-tagstring att) (vla-get-textstring att)))
	    (vlax-invoke blk 'getattributes)))
  ;; Lee Mac
  ;; https://www.theswamp.org/index.php?topic=46547.0
  (defun LM:vl-getmleaderatts ( obj / rtn )
    (if (and (= "AcDbMLeader"  (vla-get-objectname  obj))
	     (= acblockcontent (vla-get-contenttype obj)))
      (vlax-for sub (vla-item (vla-get-blocks (vla-get-document obj))
			      (vla-get-contentblockname obj))
	(if (= "AcDbAttributeDefinition" (vla-get-objectname sub))
	  (setq rtn (cons (cons (vla-get-tagstring sub)
				(vla-getblockattributevalue obj (LM:objectid sub)))
			  rtn)))))
    (reverse rtn))
  ;; ObjectID  -  Lee Mac
  ;; Returns a string containing the ObjectID of a supplied VLA-Object
  ;; Compatible with 32-bit & 64-bit systems
  (defun LM:objectid ( obj )
    (eval (list 'defun 'LM:objectid '(obj)
		(if (and (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
			 (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring))
		  (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
		  '(itoa (vla-get-objectid obj)))))
    (LM:objectid obj))
  ;; Active Document  -  Lee Mac
  ;; Returns the VLA Active Document Object
  (defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc))
  (defun sum-and-groupby-three (lst / groups res sum tmp)
    (while lst
      (setq tmp (car lst)
	    sum (apply '+
		       (mapcar 'atoi (mapcar 'cdadr
					     (setq res (vl-remove-if-not
							 '(lambda (a) (and (eq (cdr (nth 0 a)) (cdr (nth 0 tmp)))
									   (eq (cdr (nth 1 a)) (cdr (nth 1 tmp)))
									   (eq (cdr (nth 2 a)) (cdr (nth 2 tmp)))))
							 lst)))))
	    groups (cons (subst (cons "QTY" (itoa sum))(cadr tmp) tmp) groups)
	    lst (vl-remove-if '(lambda (a) (member a res)) lst)))
    (reverse groups))
  (if (setq ss (ssget '((-4 . "<OR")
			(-4 . "<AND") (0 . "INSERT") (66 . 1) (-4 . "AND>")
			(0 . "MULTILEADER") (-4 . "OR>"))))
    (progn
      (repeat (setq i (sslength ss))
	(setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
	      tabledata (cons (if (= "AcDbMLeader" (vla-get-objectname  obj))
				(LM:vl-getmleaderatts obj)
				(LM:vl-getattributes obj))
			      tabledata)))
      (print tabledata)
      (setq headers (mapcar 'car (car tabledata))
	    tags    headers
	    tabledata (sum-and-groupby-three tabledata)
	    tabledata (mapcar '(lambda (x) (mapcar 'cdr x))
			      tabledata))
      ;; sort by "A1" :
      (setq tabledata (vl-sort   tabledata '(lambda (a b)(< (car a)(car b)))))
      (setq total 0)
      (foreach i datalist (setq total (+ total (cdr i))))
      (initget 6)
      (setq txtheight (cond ((getreal "\nSpecify Text height for the table <50>: "))
			    (50))) ;<-- text height as for as in your drawing
      (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object)))))
      (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))))
      (setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa (atoi (getvar "acadver"))))))
      (setq pt (getpoint "\nSpecify table location:")
	    atable (vla-addtable
		     acsp
		     (vlax-3d-point pt)
		     (+ 2 (length tabledata))
		     (length headers)
		     (* txtheight 1.2)
		     (* txtheight 20)))
      (vla-put-regeneratetablesuppressed atable :vlax-true)
      ;; calculate column widths :
      (setq swap (append (list headers) tabledata)
	    widths nil)
      (while (car swap)
	(setq column (mapcar 'car swap)
	      colwidth (* 1.2 (apply 'max (mapcar 'strlen column)) txtheight)
	      widths (cons colwidth widths)
	      swap (mapcar 'cdr swap)))
      (setq widths (reverse widths))
      ;; set column widths
      (setq col 0)
      (foreach wid widths
	(vla-setcolumnwidth atable col wid)
	(setq col (1+ col)))
      (vla-put-horzcellmargin atable (* txtheight 0.5))
      (vla-put-vertcellmargin atable (* txtheight 0.3))
      (vla-setTextheight atable 1 txtheight)
      (vla-setTextheight atable 2 txtheight)
      (vla-setTextheight atable 4 txtheight)
      (vla-setText atable 0 0 "ATTRIBUTE SUMMARY")
      (vla-SetCellAlignment atable 0 0 acMiddleCenter)
      (vla-put-colorindex accol 2)
      (vla-setcellcontentcolor atable 0 0 accol)
      (setq col -1)
      (foreach descr headers
	(vla-setText atable 1 (setq col (1+ col)) descr)
	(vla-SetCellAlignment atable 1 col acMiddleCenter)
	(vla-setcellcontentcolor atable 1 col accol))
      (vla-put-colorindex accol 4)
      (setq row 2)
      (foreach record tabledata
	(setq col 0)
	(foreach item record
	  (vla-setText atable row col item)
	  (if (= 1 col)
	    (vla-SetCellAlignment atable row col acMiddleCenter)
	    (vla-SetCellAlignment atable row col acMiddleLeft))
	  (vla-setcellcontentcolor atable row col accol)
	(setq row (1+ row)))
      (vla-put-width atable (apply '+ widths))
      (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight))
      (vla-put-regeneratetablesuppressed atable :vlax-false)))
  (if  accol (vlax-release-object accol))
  (if  acapp (vlax-release-object acapp))
  (princ)
(prompt "\n\t---\tStart command with COUNTATT\t---\n")
(princ)
C.Utzinger
Here the rest of the Blocks
ВeekeeCZ
Ok, see the original thread HERE
