Change Object's Layer keeping LineType property.
GeryKnee
Message 1 of 9
GeryKnee
I need folowing Lisp code:
If current (active) selection exists,
for every item of selection,
Let ItemLayer=Item.layer
About Item properties:
Set  Item.layer = ActiveLayer
Set  Item.Color = AcBylayer
LineType:
If Item.LineType="Bylayer" -> Set LineType to ItemLayer.LineType
Replies (8)
Message 2 of 9
Kent1Cooper
LineType:
I'm not familiar with that code language, but if I'm interpreting it correctly, try this [untested]:
(if (setq ss (ssget "_I")); there's a selection
  (repeat (setq n (sslength ss)); then
    (setq
      ent (ssname ss (setq n (1- n)))
      edata (entget ent)
    ); setq
    (entmod
      (append
        edata
        (list (assoc 6 (tblsearch "layer" (cdr (assoc 8 edata))))); linetype of its Layer
        '((62 . 256)); color ByLayer
      ); append
    ); entmod
  ); repeat
); if
Kent Cooper, AIA
Message 3 of 9
GeryKnee
Hello Kent,
Unfortunatelly, the code is not doing the work must do.
As you say, the syntax is not familiar to you.
Let Current layer be "0"
An Item  (member of current selection) wich
Lays On Lay1 and has Color property ByLayer and LineType ByLayer
         Layer Lay1  has Color property Red and LineType ByLayer AcadIso02W100
After Routine
Item Lays on "0" with Color Bylayer as any other item selected; (color maybe changes)
But the Line type hat to remain same. So Line type will be  the Line type of Lay1.
Gery.
Message 4 of 9
GeryKnee
Hello Kent,
As you say, my syntax is not familiar to you.
an example
Let Current layer be "0" coloured blue
         , the Layer Lay1  has Color property Red and LineType AcadIso02W100
After Routine
Item Lays on "0" with Color Bylayer (now i see it blue) as any other item selected;
But the Line type hat to remain same (to be viewed as before) .
     So Line type will be  the Line type of Lay1 .New Line Type is not ByLayer but AcadIso02W100
Gery.
Message 5 of 9
Kent1Cooper
    (setq
      edata (entget ent)
    ); setq
    (entmod
      (append
        edata
        (list (cons 8 (getvar 'clayer))); put on current Layer
      ); append
    ); entmod
  ); repeat
); if
Kent Cooper, AIA
Message 6 of 9
GeryKnee
Yes Kent,
Exactly this
Thenk you very muxh
Gery.
Message 7 of 9
carlos_delaTorreQ8DF9
HI,
I'm very new with this topic, I know now how to use this LISP, but i really need this. can you explain me a bit more how to make it run. thanks very much
Message 8 of 9
Kent1Cooper
Copy this version, put into a command definition:
(defun C:WHATEVER (/ ss n ent edata)
      (setq
        edata (entget ent)
      ); setq
      (entmod
        (append
          edata
        ); append
      ); entmod
    ); repeat
  ); if
  (prin1)
Paste it into a plain-text editor such as Notepad.  Change WHATEVER to a command name that will be meaningful to you.  Save it to a file with a .lsp filetype ending.
In a drawing, use the APPLOAD command, navigate to where you saved it, and Load it.
As written [because that was the context in Message 1], it requires you to SELECT OBJECTS FIRST, then enter the command name.  If you prefer, it could be modified to not require pre-selection of objects, but to permit that but also let you enter the command name first and then be asked to select objects.
Kent Cooper, AIA
Message 9 of 9
thaks very much, it worked like a charm!
Kind Regards
Carlos
