Change layer VPcolor
jbear0000
jbear0000
My company uses the attached lisp file to automatically screen back all layers that are turned on and that are set to the colors in the attached screen.txt file. The lisp changes the layer globally. What would I need to change about this lisp to make it just change the layers in whatever viewport is active? Maybe that isn't even possible, but if it is a simple change to this lisp then I'd appreciate the help.
pbejse
Would you settle for selecting a viewport ?
(Defun _XrefColorMatch (l / a lst)
  (while (setq a (tblnext "Layer" (null a)))
    (if	(and
	  (wcmatch (setq xln (cdr (assoc 2 a))) "*|*")
	  (setq xlc (assoc (cdr (assoc 62 a)) l))
      (setq
	lst (cons (list xlc xln) lst)
  )lst
(defun c:colorscreensel ( / clrset avp)
  (setvar "CMDECHO" 0)
  (setq clrset (COLOR_SET))
  (setq xrcdata (_XrefColorMatch clrset))
  (if (and
	(zerop (getvar 'Tilemode))
	(setq avp (ssget "_+.:E:S" '((0 . "VIEWPORT"))))
	(setq avp (ssname avp 0)))
    (progn
	  (command "vpLAYER")
		(While (setq vpl (car xrcdata))
		  (prompt (strcat "\nLayer [" (cadr vpl) "] from color "
	           (itoa (caar vpl))  " to new color " (itoa (cadar vpl)))
		  (command "_Color" (cadar vpl) (cadr vpl) "_Select" avp "")
		  (setq xrcdata (cdr xrcdata))
	(command "")
   )(princ)
command: colorscreensel
You still need the COLOR_SET subfunction
HTH
jbear0000
Thank you! That is perfect!
pbejse
Good for you@jbear0000, You are welcome
