change center of circle after use USC
xuantientutungXUK6E
Message 1 of 8
xuantientutungXUK6E
hi guys,
i want to change the center of circles to usc cordinate.
but after i change wsc to usc, i use getproperites 'center.... and the point center is still in WSC.
does it anyway to change it to new usc.
hope i can get any suggestions.
thank you.
Replies (7)
Message 2 of 8
ВeekeeCZ
Use the TRANS function
(trans (getpoint)  0 1)
Message 3 of 8
xuantientutungXUK6E
thank you so much!
Message 4 of 8
can you please explain the how it will work.
Message 5 of 8
xuantientutungXUK6E
hi,
i need to change the coordinate of the circle center from WSC to USC. But after i change Autocad to USC coordinate, the center i get when i use the command (getproperties 'center...........) is still in WSC.
So use (trans (getproperties 'center........) 0 1), the point will change in to USC.
thanks.
Message 6 of 8
thanks for reply.
but still not get what you need, and the commands you used.
can you please reply step by step and post some screenshot if possible.
sorry for inconvience.
Message 7 of 8
xuantientutungXUK6E
try these code, and use F2 to open consle and see what it be
(setq pttrong(getpoint ))
(setq wp(getpoint))
(command "_.ucs" wp pause pttrong) ; code to make UCS
(setq cirpt(getpoint )); code to choice center of a circle
(setq cirpt1 (trans cirpt 0 1) ); code change cirpt from WCS to UCS.
(princ cirpt )
(princ "change to" )
(princ cirpt1)
Message 8 of 8
Kent1Cooper
@xuantientutungXUK6E wrote:
....i want to change the center of circles to usc cordinate.
[That's WCS and UCS, by the way -- initials for Coordinate System.]  Depending on how you need to use the information, there could be a much easier way.  If you don't need to save it in code for some kind of calculations or the like, but you just want the center to be reported  to you in coordinates of the current UCS, just use the LIST command.
Kent Cooper, AIA
