adds vertices at intersection of polyline with a Block Line
is it possible to change the lisp so it can select a trim line from block and add vertex at that line intersection to selected polylines?
the below codes adds vertices at intersection of polyline with a polyline, can it be changed to so that i can select a line from a block and add vertex to intersecting polylines with that one.
;;; plintav1 - adds vertices at intersection of pline and selection set of curves ;;; (defun c:plintav1 ( / intersobj1obj2 LM:Unique AT:GetVertices member-fuzz add_vtx s1 ss ent n entx intpts intptsall plpts par f ) (vl-load-com) (defun intersobj1obj2 ( obj1 obj2 / coords pt ptlst ) (if (eq (type obj1) 'ENAME) (setq obj1 (vlax-ename->vla-object obj1))) (if (eq (type obj2) 'ENAME) (setq obj2 (vlax-ename->vla-object obj2))) (setq coords (vl-catch-all-apply 'vlax-safearray->list (list (vl-catch-all-apply 'vlax-variant-value (list (vla-intersectwith obj1 obj2 AcExtendNone)))))) (if (vl-catch-all-error-p coords) (setq ptlst nil) (repeat (/ (length coords) 3) (setq pt (list (car coords) (cadr coords) (caddr coords))) (setq ptlst (cons pt ptlst)) (setq coords (cdddr coords)) ) ) ptlst ) (defun LM:Unique ( lst ) (if lst (cons (car lst) (LM:Unique (vl-remove (car lst) (cdr lst))))) ) (defun AT:GetVertices ( e / p l ) (LM:Unique (if e (if (eq (setq p (vlax-curve-getEndParam e)) (fix p)) (repeat (setq p (1+ (fix p))) (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l)) ) (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e)) ) ) ) ) (defun member-fuzz ( expr lst fuzz ) (while (and lst (not (equal (car lst) expr fuzz))) (setq lst (cdr lst)) ) lst ) (defun add_vtx ( obj add_pt ent_name / bulg sw ew ) (vla-GetWidth obj (fix add_pt) 'sw 'ew) (vla-addVertex obj (1+ (fix add_pt)) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 0 1)) (list (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name)) ) ) ) ) (setq bulg (vla-GetBulge obj (fix add_pt))) (vla-SetBulge obj (fix add_pt) (/ (sin (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) (cos (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4)) ) ) (vla-SetBulge obj (1+ (fix add_pt)) (/ (sin (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) (cos (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4)) ) ) (vla-SetWidth obj (fix add_pt) sw (+ sw (* (- ew sw) (- add_pt (fix add_pt))))) (vla-SetWidth obj (1+ (fix add_pt)) (+ sw (* (- ew sw) (- add_pt (fix add_pt)))) ew) (vla-update obj) ) (prompt "\nPick source POLYLINE...") (setq s1 (ssget "_+.:E:S:L" (list '(0 . "*POLYLINE") '(-4 . "<or") '(70 . 0) '(70 . 1) '(70 . 128) '(70 . 129) '(-4 . "or>") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model"))))) (while (not s1) (prompt "\nMissed... Try picking source POLYLINE on unlocked layer again...") (setq s1 (ssget "_+.:E:S:L" (list '(0 . "*POLYLINE") '(-4 . "<or") '(70 . 0) '(70 . 1) '(70 . 128) '(70 . 129) '(-4 . "or>") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model"))))) ) (prompt "\nNow select intersecting curves...") (setq ss (ssget (list '(0 . "*POLYLINE,SPLINE,LINE,ARC,CIRCLE,ELLIPSE,HELIX,RAY,XRAY") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model"))))) (while (not ss) (prompt "\nEmpty sel.set... Please reselect intersecting curves again...") (setq ss (ssget (list '(0 . "*POLYLINE,SPLINE,LINE,ARC,CIRCLE,ELLIPSE,HELIX,RAY,XRAY") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model"))))) ) (setq ent (ssname s1 0)) (if (= (cdr (assoc 0 (entget ent))) "POLYLINE") (progn (command "_.CONVERTPOLY" "_L" ent "") (entupd (setq ent (entlast))) (vla-update (vlax-ename->vla-object ent)) (setq f t) ) ) (repeat (setq n (sslength ss)) (setq entx (ssname ss (setq n (1- n)))) (setq intpts (intersobj1obj2 ent entx)) (setq intptsall (append intpts intptsall)) ) (foreach intpt intptsall (setq plpts (AT:GetVertices ent)) (if (and (not (member-fuzz intpt plpts 1e-6)) (setq par (vlax-curve-getparamatpoint ent (vlax-curve-getclosestpointto ent intpt))) ) (add_vtx (vlax-ename->vla-object ent) par ent) ) ) (if f (progn (command "_.CONVERTPOLY" "_H" ent "") (entupd (setq ent (entlast))) (vla-update (vlax-ename->vla-object ent)) ) ) (princ) )
