adds vertices at intersection of polyline with a Block Line
mint09
mint09
is it possible to change the lisp so it can select a trim line from block and add vertex at that line intersection to selected polylines?
the below codes adds vertices at intersection of polyline with a polyline, can it be changed to so that i can select a line from a block and add vertex to intersecting polylines with that one.
;;; plintav1 - adds vertices at intersection of pline and selection set of curves ;;;
(defun c:plintav1 ( / intersobj1obj2 LM:Unique AT:GetVertices member-fuzz add_vtx
                      s1 ss ent n entx intpts intptsall plpts par f )
  (vl-load-com)
  (defun intersobj1obj2 ( obj1 obj2 / coords pt ptlst )
    (if (eq (type obj1) 'ENAME) (setq obj1 (vlax-ename->vla-object obj1)))
    (if (eq (type obj2) 'ENAME) (setq obj2 (vlax-ename->vla-object obj2)))
    (setq coords (vl-catch-all-apply 'vlax-safearray->list (list (vl-catch-all-apply 'vlax-variant-value (list (vla-intersectwith obj1 obj2 AcExtendNone))))))
    (if (vl-catch-all-error-p coords)
      (setq ptlst nil)
      (repeat (/ (length coords) 3)
        (setq pt (list (car coords) (cadr coords) (caddr coords)))
        (setq ptlst (cons pt ptlst))
        (setq coords (cdddr coords))
    ptlst
  (defun LM:Unique ( lst )
    (if lst (cons (car lst) (LM:Unique (vl-remove (car lst) (cdr lst)))))
  (defun AT:GetVertices ( e / p l )
    (LM:Unique
      (if e
        (if (eq (setq p (vlax-curve-getEndParam e)) (fix p))
          (repeat (setq p (1+ (fix p)))
            (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l))
          (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e))
  (defun member-fuzz ( expr lst fuzz )
    (while (and lst (not (equal (car lst) expr fuzz)))
      (setq lst (cdr lst))
    lst
  (defun add_vtx ( obj add_pt ent_name / bulg sw ew )
      (vla-GetWidth obj (fix add_pt) 'sw 'ew)
      (vla-addVertex
          obj
          (1+ (fix add_pt))
          (vlax-make-variant
              (vlax-safearray-fill
                  (vlax-make-safearray vlax-vbdouble (cons 0 1))
                      (list
                          (car (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
                          (cadr (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name))
      (setq bulg (vla-GetBulge obj (fix add_pt)))
      (vla-SetBulge obj
          (fix add_pt)
              (sin (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4))
              (cos (/ (* 4 (atan bulg) (- add_pt (fix add_pt))) 4))
      (vla-SetBulge obj
          (1+ (fix add_pt))
              (sin (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4))
              (cos (/ (* 4 (atan bulg) (- (1+ (fix add_pt)) add_pt)) 4))
      (vla-SetWidth obj (fix add_pt) sw (+ sw (* (- ew sw) (- add_pt (fix add_pt)))))
      (vla-SetWidth obj (1+ (fix add_pt)) (+ sw (* (- ew sw) (- add_pt (fix add_pt)))) ew)
      (vla-update obj)
  (prompt "\nPick source POLYLINE...")
  (setq s1 (ssget "_+.:E:S:L" (list '(0 . "*POLYLINE") '(-4 . "<or") '(70 . 0) '(70 . 1) '(70 . 128) '(70 . 129) '(-4 . "or>") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model")))))
  (while (not s1)
    (prompt "\nMissed... Try picking source POLYLINE on unlocked layer again...")
  (prompt "\nNow select intersecting curves...")
  (setq ss (ssget (list '(0 . "*POLYLINE,SPLINE,LINE,ARC,CIRCLE,ELLIPSE,HELIX,RAY,XRAY") (cons 410 (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model")))))
  (while (not ss)
    (prompt "\nEmpty sel.set... Please reselect intersecting curves again...")
  (setq ent (ssname s1 0))
  (if (= (cdr (assoc 0 (entget ent))) "POLYLINE")
    (progn
      (command "_.CONVERTPOLY" "_L" ent "")
      (entupd (setq ent (entlast)))
      (vla-update (vlax-ename->vla-object ent))
      (setq f t)
  (repeat (setq n (sslength ss))
    (setq entx (ssname ss (setq n (1- n))))
    (setq intpts (intersobj1obj2 ent entx))
    (setq intptsall (append intpts intptsall))
  (foreach intpt intptsall
    (setq plpts (AT:GetVertices ent))
    (if
      (and
        (not (member-fuzz intpt plpts 1e-6))
        (setq par (vlax-curve-getparamatpoint ent (vlax-curve-getclosestpointto ent intpt)))
      (add_vtx (vlax-ename->vla-object ent) par ent)
  (if f
    (progn
      (command "_.CONVERTPOLY" "_H" ent "")
  (princ)
ВeekeeCZ
Looks like @marko_ribar 's code.
