- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to change the visibility state of a dynamic block on multiple drawings without opening the drawing. I have a bat file that executes accoreconsole, I have a script that successfully runs the lisp routine to change the state in an open drawing but I can't figure out how to run the lisp in the script using the accoreconsole to change the visibility state without opening the drawing. The dynamic block name is "drawing status stamp", the lisp routine name is "changevis_permit.lsp", the script name is "CHANGEVIS_PERMIT.SCR". I am relatively new to using accoreconsole, bats,scripts and lisp so please keep any explanation simple. I realize that using accoreeconsole may not be the correct approach but it is the only way I know to execute a command on drawings without opening them.
Thank you!
