Update Boundary Width of multi line attribute
aeldrawingoffice
Message 1 of 8
aeldrawingoffice
Hi
I have a couple hundred of borders that have a multi-line attribute within them that needs it's boundary width updated to 115
The attributes name within the border is DRAWING_STATUS
What I'm looking to do is run a script over these drawings that will open these drawings, call a lisp routine to update the boundary width on this one particular attribute, zoom extents and save.
Is there anyone that could help with this please.
Simon
Replies (7)
Message 2 of 8
devitg
@aeldrawingoffice Please upload a sample.dwg
With a before and after , as you need it.
Message 3 of 8
aeldrawingoffice
files attached.
Attribute is bottom left.  Currently populated with the work MASTER
Message 4 of 8
pbejse
The block "TE_1-250_A1_1030" is on Model space?
Message 5 of 8
pbejse
Download this support file ObjectDBX Wrapper
Load the above file along with the code below.
(defun c:MTBW ( / _MTWdithTo115)
(defun _MTWdithTo115 ( doc / f)
 	(vlax-for atb (Vla-get-modelspace doc)
	  (if
	    (and
		    (vlax-write-enabled-p atb)
		    (eq (Vla-get-objectname atb) "AcDbBlockReference")
		    (eq (if (vlax-property-available-p atb 'effectivename)
	                                        (vla-get-effectivename atb)
	                                        (vla-get-name atb)
							"TE_1-250_A1_1030")
		    (minusp (Vlax-get atb 'HasAttributes))
		    (setq f (assoc "DRAWING_STATUS" (mapcar '(lambda (at)
							       (list (vla-get-TagString at) at))
							    (Vlax-invoke atb 'GetAttributes))))
	    (progn
	  	(vlax-put (cadr f) 'MTextBoundaryWidth 115.00)
  		(princ (Strcat "\n Block at " (vl-filename-base  (vla-get-name doc)) " modified" )))
	(LM:ODBX '_MTWdithTo115 nil t)
  (princ)
HTH
Message 6 of 8
aeldrawingoffice
Thanks for the help and effort.
I ran this on one of the drawings but got the error below
Command: MTBW
; error: no function definition: LM:ODBX
Message 7 of 8
devitg
Message 8 of 8
pbejse
Command: MTBW
How was it that you were able to load MTBW but not the other one?  As intructed before at post #5
You can follow the link posted by  @devitg on the previous post as well
HTH
