Change basic object properies from "bylayer" to corresponding layer properties.
GeryKnee
Message 1 of 11
GeryKnee
Lisp Code :::
in current (active) selection,
for every item of selection,
Let ItemLayer=Item.layer
if(Item.color="Bylayer" -> Set Item.Color to ItemLayer.Color
If Item.LineType="Bylayer" -> Set LineType to ItemLayer.LineType
Gery
Replies (10)
Message 2 of 11
ВeekeeCZ
This is what I use.
(vl-load-com)
(defun c:SetByLayerReverse (/ *error* adoc layer obj en ss i )
  (defun *error* (msg)
    (vla-endundomark adoc)
    (princ msg)
    (princ))
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (if (setq ss (ssget))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i)))
	    obj (vlax-ename->vla-object en)
	    layer (vla-get-layer obj))
      (if (not (assoc 62 (entget en)))
	(vla-put-color obj (cdr (assoc 62 (tblsearch "layer" layer)))))
      (if (not (assoc 6 (entget en)))
	(vla-put-linetype obj (cdr (assoc 6 (tblsearch "layer" layer)))))
      (if (not (assoc 370 (entget en)))
	(vla-put-lineweight obj (cond ((cdr (assoc 370 (entget (tblobjname "layer" layer)))))
				      (-3))))))
  (princ)
Message 3 of 11
dbroad
First, I think the idea is lousy.  Using bylayer properties is far better and more manageable than assigning individual properties to objects themselves. That said, this is the most direct coding for your vba psuedo code.
;;Change selected object properties to object layer's properties.
(defun c:foo ( / doc lays lay prop);D.C.Broad,Jr.
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq lays (vla-get-layers doc))
  (if (ssget)
    (vlax-for n	(vla-get-activeselectionset doc)
      (setq lay (vla-item lays (vla-get-layer n)))
      (foreach prop '(color linetype)	;plotstyle, transparency, etc.
	(if (= acbylayer (vlax-get n prop))
	  (vlax-put n prop (vlax-get lay prop))
  (princ)
Architect, Registered NC, VA, SC, & GA.
Message 4 of 11
GeryKnee
Yes Sir,
Thank you very much.
Gery.
Message 5 of 11
GeryKnee
That's working too
Thank you,
Gery
Message 6 of 11
GeryKnee
Is this ok for ByBlock plus to Bylayer ???
(if (ssget)
(if (= acbyblock (vlax-get n prop))
(princ)
Message 7 of 11
dbroad
You're welcome.
In addition, in rare cases, the property might not be applicable to the object. To accommodate those cases, the code within the foreach should be modified to be:
(if (and (vlax-property-available-p n prop)(= acbylayer (vlax-get n prop)))
Message 8 of 11
dbroad
To accomodate bylayer and byblock, I would recommend:
(defun c:foo  ()
  (if (ssget)
		 (member (vlax-get n prop) (list acbylayer acbyblock))
		 (vlax-put n prop (vlax-get lay prop)))))))
  (princ))
IMO, only the byblock properties should be assigned to layer properties.
Message 9 of 11
GeryKnee
Yes,
That's very good.
Can after routine execution, selected objecs remain selected???
Message 10 of 11
dbroad
Actually, due to quirks in AutoCAD's implementation of bylayer and byblock, only this will probably work:
(defun c:foo  ( / doc lays lay ss prop)
			 (list acbylayer acbyblock "ByLayer" "Byblock")))
  (sssetfirst nil ss)
  (princ))
Message 11 of 11
GeryKnee
Yes,
Thats not working.
Theres a need here,
I resend :
Lisp Code :::
About Item properties:
Set  Item.layer = ActiveLayer
Set  Item.Color = AcBylayer
The Other properies LineType etc
If Item.LineType="Bylayer" or "Byblock" -> Set LineType to ItemLayer.LineType
