Message 1 of 9
help to modify lisp
Hi everyone,
could you help me to modify the following lisp. the section is defined to only one viewport at a time, and I would like to be able to select several viewports at the same time.
;LISP SCALE VIEWPORT
(defun c:ee (/ e s)
(if (setq e (car (entsel "\nSelecciona el Viewport: ")))
(if (eq "AcDbViewport" (vla-get-objectname (setq e (vlax-ename->vla-object e))))
(if (setq s (getreal (strcat "\nNueva Escala (Actual: 1\/"
(rtos (/ 1000. (vla-get-customscale e)) 2)
(vl-catch-all-apply (function vla-put-customscale) (list e (/ 1000. s)))
(princ "\nInvalid object!")
(princ)
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
