Certain custom Autolisp Routines quit working in AutoCAD 2025 error: no function definition: acet-ui-message
Sean.Boseman
Message 1 of 19
Sean.Boseman
Hello, I've been using a couple custom lisp routines for several years now that appear to not work in AutoCAD 2025, yet they've worked in all previous versions. I have both 2024 and 2025 installed and the routines still work perfectly on 2024, but in 2025 I receive the message "error: no function definition: acet-ui-message". Will ask you whether you want to plot to the printer and if so, ask how many copies and will proceed to print to our particular printer. If you say no, it will just change the current drawing's plot settings to our desired settings. Does anyone one know why all of a sudden the long used lisp routine stopped working for AutoCAD 2025? is this just a bug? See below copy of the program, I've also attached the file. I appreciate the help in advance.
(defun c:isg (/ a k qty)
(setq k (acet-ui-message "Do you really want to print a color copy to the ISG Printer?" "Print Confirmation:" 52))
(if (= k 6)
(progn
(setq qty nil)
(setq qty (getreal "\nEnter number of copies <1>:"))
(if (= qty nil) (setq qty 1))
(setvar "cmdecho" 0)
(setq a (getvar "tilemode"))
(while (/= qty 0)
(progn
(if (= a 0)
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "no" "no" "no" "no" "yes" "yes")
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "as" "no" "yes" "yes")
(command)
(setq qty (- qty 1))
(progn
(if (= a 0)
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "no" "no" "no" "no" "yes" "no")
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "as" "no" "yes" "no")
(command)
(princ)
Replies (18)
Message 2 of 19
CLL_PBE
acet-ui-message is an Express Tools function that displays a message box.
Perhaps check if you have Express Tool installed for 2025?
Message 3 of 19
Sean.Boseman
Express Tool does appear to be installed for 2025.
Message 4 of 19
pendean
Community Legend
Community Legend
try running a couple of Express tools (start to finish), if they work fine, try your LISP again.
Message 5 of 19
Sean.Boseman
Wow, that seems to work! Any idea why I have to run an express tool for the routine to work? I've never had that happen before in subsequent AutoCAD versions. Is this some sort of glitch with 2025?
Message 6 of 19
pendean
Community Legend
Community Legend
Wow, that seems to work!...
Message 7 of 19
Sean.Boseman
The value appeared to be already set to 3.
Message 8 of 19
komondormrex
it seems so. add this expression (load "acetutil") at the beginning of your code.
Message 9 of 19
Sean.Boseman
excellent, that worked! Thank you!
Message 10 of 19
ВeekeeCZ
AutoCAD 2025 does not preload express tools automatically anymore. They wanted to speed up the application startup. So now there is a new function. It works similarly to vl-load-com.
(acet-load-expresstools)
See HELP
Message 11 of 19
1wildwes
I've tried inserting that expression before and after the (DEFUN C:XD (/ bl blst ent ans).  There are indentions shown in the attached. Are you able to tell me exactly where to insert the expression? Thanks!
(load "acetutil")
(setq bl (entsel))
(setq blst (entget (car bl)))
(setq ent (cdr (assoc 0 blst)))
(if (= ent "INSERT")
(progn
(setq xname (cdr (assoc 2 blst)))
(CHKREF)
(if (= check_val 1)
Message 12 of 19
1wildwes
Full lsp attached
Message 13 of 19
pendean
Community Legend
Community Legend
@1wildwes wrote:
Full lsp attached
Use the other tip
Seems to work here.
Message 14 of 19
komondormrex
you can put it any place outside any function. but very top is likely to be the best place.
thou did not find any et function in your code.
Message 15 of 19
rgrainer
first line after defun
Message 16 of 19
btillett
Seem to need that in 2026 as well.
Boris
Message 17 of 19
Sea-Haven
Maybe something like this, you can add how many prints to the dcl also.
(defun yesno ( / butval)
(defun butval ( / )
    (if  (= (get_tile "Rb1") "1" )
        (setq colprint "yes")
		(setq colprint "no")
(setq dcl (vl-filename-mktemp nil nil ".dcl") )
(setq des (open dcl "w") )
(foreach x
"yesno : dialog 	{"
"	label =\"Print color copy to ISG Printer\" ;"
"	: row	{"
"	: boxed_radio_row	{"
"	: radio_button	{"
"key = \"Rb1\";"
"label = \"Yes\";"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb2\";"
"label = \"No\";"
"spacer_1 ;"
"spacer_1 ;"
"	ok_cancel;"
(write-line x des )
(close des)
(setq dcl_id (load_dialog dcl))
(if (not (new_dialog "yesno" dcl_id) )
(exit)
(action_tile "accept" "(butval)(done_dialog)")
(action_tile "cancel" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
(vl-file-delete dcl)
(princ )
Message 18 of 19
btillett
Not sure I would add 45 lines of code to replace what can be done with just 2 lines.
But the box looks nice thank you!
;--------------Warning to continue
(load "acetutil")
(if (= (acet-ui-message "You are about to change your layer settings. Ok to proceed?" "pick ok or Cancel" 1) 2)(exit))
Boris
Message 19 of 19
Sea-Haven
Ok the short version. 3 lines. The multi radio buttons.lsp is a global program and can be used in any code you want to write. Multi getvals, Multi toggles also, as well as a few more global make dcl's. Just save in a support path. Examples in top of code. It was used to make the dcl code in the lisp.
(if (not AH:Butts)(load "Multi radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "H"   '("Print color copy to ISG Printer" "Yes" "No" )))
Ans returns "Yes" or "No", a hidden option is variable "but" returns 1 or 2 useful when you have long descriptions. Replace "H" with "V" and a vertical dcl is made.
