- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I've been using a couple custom lisp routines for several years now that appear to not work in AutoCAD 2025, yet they've worked in all previous versions. I have both 2024 and 2025 installed and the routines still work perfectly on 2024, but in 2025 I receive the message "error: no function definition: acet-ui-message". Will ask you whether you want to plot to the printer and if so, ask how many copies and will proceed to print to our particular printer. If you say no, it will just change the current drawing's plot settings to our desired settings. Does anyone one know why all of a sudden the long used lisp routine stopped working for AutoCAD 2025? is this just a bug? See below copy of the program, I've also attached the file. I appreciate the help in advance.
(defun c:isg (/ a k qty)
(setq k (acet-ui-message "Do you really want to print a color copy to the ISG Printer?" "Print Confirmation:" 52))
(if (= k 6)
(progn
(setq qty nil)
(setq qty (getreal "\nEnter number of copies <1>:"))
(if (= qty nil) (setq qty 1))
(setvar "cmdecho" 0)
(setq a (getvar "tilemode"))
(while (/= qty 0)
(progn
(if (= a 0)
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "no" "no" "no" "no" "yes" "yes")
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "as" "no" "yes" "yes")
(command)
(setq qty (- qty 1))
(progn
(if (= a 0)
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "no" "no" "no" "no" "yes" "no")
(command "-plot" "y" "" "\\\\print\\SALES_KM_C558" "11x17" "inches" "landscape" "no" "extents" "fit" "center" "no" "" "yes" "as" "no" "yes" "no")
(command)
(princ)
