LISP for creating field off a selected object, grabbing specific attribute
MichaelD061
MichaelD061
Looking to create an autocad lisp that allows me to select an object and places a field parameter regarding that specific block's attribute titled CIRCUIT#. Original thought process was to select an object, grab its id, then place field parameter. It should autoselect field category as object, the object type should be the object that I selected, property should be Circuit#, and format should be (none).
For reference, here are two examples of the field expression for two objects.
%<\AcObjProp Object(%<\_ObjId 1770506033232>%).TextString>%
%<\AcObjProp Object(%<\_ObjId 1770506022224>%).TextString>%
I have an attempt above!
(defun c:PlaceField ()
  (setq obj (car (nentselp "\nSelect an object: ")))
  (if obj
    (progn
      (setq entityId (cdr (assoc 5 (entget obj)))) ; Get the handle of the selected object
      (setq fieldText (strcat "%<\\AcObjProp Object(%<\\_ObjId " entityId ">%).Attribute(\"CIRCUIT#\")>%"))
      (command "_.FIELD" "_Object" fieldText "_Type" "Object" "_Object" entityId "_Field")
    (princ "\nNo object selected.")
; Examples of proper field expression
;<\AcObjProp Object(%<\_ObjId 1770506033232>%).TextString>%
;%<\AcObjProp Object(%<\_ObjId 1770506022224>%).TextString>%
paullimapa
One item you’re missing is the objid. An example of how to get this
(setq objid (vla-get-ObjectId (vlax-ename->vla-object enam)))
Here’s a link where you can get some ideas on how to put the field expression into an object
Paul Li
IT Specialist
@The Office
Sea-Haven
I am confused when using fields need two objects the first is the relative object eg an Attribute, the second is the destination object say a Mtext or another attribute in another block. Dont need tag name if picking an attribute.
You appear to have only 1 object in the code.
Lastly using VL can put a field textstring into a suitable object and will reflect that field.
Selecting an attribute should give this type of string, need to use nentsel to pick attribute rather than block.
%<\AcObjProp Object(%<\_ObjId 1961879984>%).TextString>%
