Center of the screen.
adaptacad
Message 1 of 22
adaptacad
Is there a way to insert a block at the same rotation as another block closer to the center of my screen?
-> I zoomed, I called the command, and the new block will be inserted in the block closest to my zoom.
I got a .dwg with the example.
Accepted solutions (4)
Replies (21)
Message 21 of 22
Kent1Cooper
@Kent1Cooper wrote:
      (command "_.insert" "Blk_Insert" "_none"
        (polar (cdr (assoc 10 (entget theOne))) (- rot (/ pi 2)) 2.5)
        1 1 rot
      ); command
Sorry, that should be:
        1 1 (angtos rot (getvar 'aunits) 8); rotation as text string in current units
      ); command
Kent Cooper, AIA
Message 22 of 22
adaptacad
Perfect @hak_vz  @Kent1Cooper  thank you!!!
