Can you do math in a text object?
atuckerJKU9U
Message 1 of 23
atuckerJKU9U
Hey all, I assume a lisp for something like this exists, it's just hard to search for.  I have a tree survey with thousands of trees, and I need to add the values of multi trunk trees together and replace with the new value.  In the image below, I want the 6",6" to say 12" instead, and the 6",7" to say 13" instead.  Typically we do this separately in a spreadsheet, but in this case I need it to be in the drawing.  Anybody know of a lisp that would do this?  Currently they are dtext, could convert them to mtext if that would help.  EG 6",6" is a single dtext.  Doing find and replace beforehand to get rid of commas, inches, adding a plus, all no problem.  Thanks!
Replies (22)
Message 21 of 23
ВeekeeCZ
An alternative workflow would be to just export all the texts to the csv file, do the math and other adjustments in Excel, then reimport the texts back to the drawing.
See here for example of such routines
https://www.cadtutor.net/forum/topic/75466-exporting-text-and-mtext-with-base-point-to-a-txt-file-an...
by BIGAL.
Message 22 of 23
komondormrex
@atuckerJKU9U
hey there,
check this different one. it won't break the command running when false enumaration occurs, as @paullimapa mentioned above. instead it will output this false enumeration as error on autocad console. valid enumeration is integers followed by the inch mark separated with comma only.
(defun string_to_list (input_string delimiter / delimiter_position output_list)
  (while (setq delimiter_position (vl-string-search delimiter input_string 0))
    (setq output_list (append output_list
                 (list (vl-string-trim " " (substr input_string 1 delimiter_position)))
        input_string (substr input_string (+ 2 delimiter_position))
  (append output_list (list (vl-string-trim " " input_string)))
(defun c:sum_text_comma (/ trunk_list trunk_asc text_dxf)
  (foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "text") (1 . "*`,*"))))))
    (if (vl-every '(lambda (trunk) (and (= 34 (last (setq trunk_asc (vl-string->list trunk))))
                       (vl-every '(lambda (asc) (member asc '(48 49 50 51 52 53 54 55 56 57)))
                          (cdr (reverse trunk_asc)))
             (setq trunk_list (string_to_list (cdr (assoc 1 (setq text_dxf (entget text)))) ","))
      (entmod (subst (cons 1 (strcat (itoa (apply '+
                            (mapcar 'atoi
                                (mapcar '(lambda (trunk) (vl-string-right-trim "\"" trunk))
                                     trunk_list
                      (assoc 1 text_dxf)
                      text_dxf
      (princ (strcat "\nError found in trunk enumeration: \""
              (cdr (assoc 1 text_dxf))
              (vl-list->string trunk_asc)
    (princ)
Message 23 of 23
pbejse
(defun c:AddThemInch ( / textStringWithComma stringValue numericalValue i)
  (if (setq textStringWithComma (ssget  '((0 . "TEXT")(1 . "#*\"`,#*\""))))
    	(repeat (Setq i (sslength textStringWithComma))
	  	(Setq stringValue (cdr (Assoc 1
					      (setq entityData (entget (ssname textStringWithComma (setq i (1- i))))))))
	  	(setq numericalValue
	  	    (  (lambda ( str / l)
	  		(while (setq p (vl-string-position 44 str nil t))
		  		(setq l (cons (atoi (substr str (+ p 2))) l)
					 str     (substr str 1 p)))
			 	l
			  ) stringValue ))
	      (entmod (subst  (cons 1 (Strcat (itoa
				(apply '+ (cons (atoi stringValue) numericalValue)))"\"")) (assoc 1 entityData) entityData))
  (princ)
