Can you do math in a text object?
atuckerJKU9U
Message 1 of 23
atuckerJKU9U
Hey all, I assume a lisp for something like this exists, it's just hard to search for.  I have a tree survey with thousands of trees, and I need to add the values of multi trunk trees together and replace with the new value.  In the image below, I want the 6",6" to say 12" instead, and the 6",7" to say 13" instead.  Typically we do this separately in a spreadsheet, but in this case I need it to be in the drawing.  Anybody know of a lisp that would do this?  Currently they are dtext, could convert them to mtext if that would help.  EG 6",6" is a single dtext.  Doing find and replace beforehand to get rid of commas, inches, adding a plus, all no problem.  Thanks!
Replies (22)
Message 2 of 23
paullimapa
So you only need the text that contain a comma “,” in a selection set or entire drawing to be added showing only the total text in inches?
Could you provide a sample dwg?
Paul Li
IT Specialist
@The Office
Message 3 of 23
atuckerJKU9U
Here's the drawing.  The texts are on a bunch of different layers.  Yes, any text that has a comma would need the numbers within added together.
Message 4 of 23
komondormrex
check this out
(entmod (subst (cons 1 (strcat (itoa (cal (vl-string-translate "\"," " +" (cdr (assoc 1 (setq text_dxf (entget (car (entsel "\nPick dtext, comma separated"))))))))) "\"")) (assoc 1 text_dxf) text_dxf))
Message 5 of 23
paullimapa
There’s no drawing attached
Paul Li
IT Specialist
@The Office
Message 6 of 23
atuckerJKU9U
Did the attachment show up? It's being weird on my end and I can't see that it uploaded.
Message 7 of 23
paullimapa
You’ll have to use your browser to accesss the forum to attach files
Paul Li
IT Specialist
@The Office
Message 8 of 23
atuckerJKU9U
Sorry, I can't program well enough to put that in a lisp.  I did try it on the command line and it didn't work.  Plus it would only let me select one at a time.  Needs to select multiple, there are hundreds of text objects to change.  I selected that long string of numbers right below the box.
Message 9 of 23
atuckerJKU9U
I was able to get it to attach to the original message.  Look there.
Message 10 of 23
komondormrex
try to run cal command before. should help.
Message 11 of 23
komondormrex
or this custom command
(arxload "geomcal")
(defun c:sum_text_comma (/ text_dxf)
  (foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "text") (1 . "*`,*"))))))
    (entmod (subst (cons 1 (strcat (itoa (cal (vl-string-translate "\"," " +" (cdr (assoc 1 (setq text_dxf (entget text))))))) "\"")) (assoc 1 text_dxf) text_dxf))
updated - missed reverse quote in the text content filter.
Message 12 of 23
atuckerJKU9U
Ah, it did work after the cal command!  Still not solved as I need to do hundreds at once.  I could figure out how to get that into a lisp, and probably to select multiple, but I have no idea how to make it add back the text to the right object when multiple were selected.
Message 13 of 23
komondormrex
check message 11
Message 14 of 23
komondormrex
need to open your dwg)
Message 15 of 23
atuckerJKU9U
Message 11 works perfect, and so fast!!!  Thanks so much!
Message 16 of 23
paullimapa
Updated @komondormrex @atuckerJKU9U
FYI, I noticed that you have in that sample drawing at least one situation:
A foot symbol instead of an inch symbol followed by a comma:
In this situation it would cause @komondormrex to error out and not process the rest of the selection set.
Perhaps you may want to use the FIND command to locate all matching situations and replace it with the proper symbol:
Paul Li
IT Specialist
@The Office
Message 17 of 23
atuckerJKU9U
You are correct about that.  This is common with surveyor files, quotes instead of parenthesis, varying numbers of spaces.  Will definitely have to keep an eye on the end product to look for items like that.  I will probably run it then search for commas to find problems.  Thanks for the heads up!
Message 18 of 23
Kent1Cooper
You could also prevent the error-out by filtering not just for Text containing a comma, but instead containing [anything leading plus] a number and an inch mark and a comma and a number [plus anything trailing].  That would mean the example 10',14" would be filtered out, so it would not be processed, but it would not prevent processing of the rest.
But that alone would not filter out one that had the erroneous foot mark after the second number.  So it might be better to filter for a number and an inch mark and a comma and a number and a wildcard * for a possible second digit and an inch mark.
Kent Cooper, AIA
Message 19 of 23
paullimapa
I agree so something like this would definitely filter out unwanted symbols:
(ssget '((0 . "text") (1 . "*\"`,*\"")))
Paul Li
IT Specialist
@The Office
Message 20 of 23
Sea-Haven
I had a similar problem finding wrong text, so added a Error function zoom to the spot where the problem is and then the user can fix, hopefully the code will be able to be rerun getting further through.
This is an example only, not a solution. looks at possible error in two functions. The error name is set in the function.
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
 (princ (strcat "\nError: " errmsg))
 (cond
 ((= errname "slopes")
 (progn
 (command "zoom" "C" pt1 25)
 (command "pline" pt2 "w" 0.075 0.075 pt3 pt4 pt5 "c")
 (command "chprop" (entlast) "" "c" 1 "")
 (alert "look for pline")
 ((= errname "renblock")
 (progn
  (command "zoom" "C" pt 25)
  (command "line" "0,0" pt "")
  (alert (strcat "I= " (rtos i 2 0) "  Error in rename block"))
 (setq *error* nil)
 (princ)
