Lisp to rename layer of a selected object
a.tawkXHKN6
Message 1 of 12
a.tawkXHKN6
I need a lisp to rename the layer of a selected object (block, polyline, line...), and keeping all the original layer format (e.g: color, linetype...)
Replies (11)
Message 2 of 12
Kent1Cooper
Something like this?
(defun C:RSOL ; = Rename Selected Object's Layer
  (command "_.rename" "_layer"
    (cdr (assoc 8 (entget (car (entsel "\nSelect object to Rename its Layer: ")))))
  ); command
); defun
Untested, but that should leave you in the command to give it the new name.  It could be enhanced to ask again if you miss in picking, and so on.
Kent Cooper, AIA
Message 3 of 12
Kent1Cooper
@Kent1Cooper wrote:
....  It could be enhanced to ask again if you miss in picking, and so on.
Another thing to be aware of:  I find that RENAME can be used on a locked Layer.  If, for whatever reason you have locked a given Layer, you would not  want it to be Renamed, the routine could be adjusted to refuse to do that, and if you like, to tell you about it, or if you prefer, ask you whether or not  you want to Rename it.
Kent Cooper, AIA
Message 4 of 12
_Tharwat
Hint: layer name "0" can not be renamed so the routine will exit with error.
Message 5 of 12
Kent1Cooper
That would be "0" [the numeral, not the letter], but yes.  I find, unexpectedly, that the DEFPOINTS Layer can  be Renamed, which I can only imagine could cause problems -- if I then draw another Dimension, it creates DEFPOINTS again, so there can be more than one Layer with Dimension DEFinition POINTS on it.  And the Renamed one can then be set to Plot.
So if there's any likelihood that the User would select something on either of those two Layers, the routine can be amended to forbid that.
Kent Cooper, AIA
Message 6 of 12
_Tharwat
Seriously ?
How did you know that it is a letter and not the numeral ?
Copy my comment to your Vslide then remove the double quotes to know where your mistake is.
Message 7 of 12
Kent1Cooper
I assumed because it looks just like a lower-case "o".  You might want to consider changing fonts to one that isn't misleading in that way.
Kent Cooper, AIA
Message 8 of 12
_Tharwat
If the reader can't differentiate between letters and digits then that is their problem.
The font style that I use is very clear and comfortable for reading.
Message 9 of 12
margonoC4PXL
; error: syntax error.
When I load this Lisp showing " (LOAD "C:/Users/margono/Downloads/RSOL.lsp") ; error: syntax error " any idea why this happen Sir?
I use autocad 2025.
Message 10 of 12
BlackBox_
Another way of doing this, which accounts for layers 0 (zero), Defpoints, among other things:
https://apps.autodesk.com/ACD/en/Detail/Index?id=3752103605651655897&appLang=en&os=Win32_64
Cheers
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 11 of 12
Kent1Cooper
 ....any idea why this happen Sir?
As I said, it was untested.  It was missing the parentheses for the localized variables list, which are needed even if there's nothing in them:
(defun C:RSOL (); = Rename Selected Object's Layer
  ); command
I have to assume the OP [who marked it an accepted solution, so they must have gotten it to work] supplied those for themselves.
Kent Cooper, AIA
Message 12 of 12
margonoC4PXL
Ok, thank you sir already work.
I thought I would just add the name from original but this requires creating the new name.
