Can you correct & complete the code?
smallƑish
smallƑish
Looking for preview while pressing "tab" key circle of diameter of 100, 200, 300, respectively each press.  then 4th press back to 100 and mouse clicks to draw the chosen diameter circle.
(defun c:z2 (/)
(setq p1 (getpoint "\np1"));center of circle
(setq option1 (command "_.circle" p1 "d" "100" "" ))
(setq option2 (command "_.circle" p1 "d" "200" "" ))
(setq option2 (command "_.circle" p1 "d" "300" "" ))
(grread (option1 option2 option3 ))
Accepted solutions (3)
ВeekeeCZ
What behavior are you expecting from GRREAD that you're wanting so badly?
PS. Convince yourself to no more trying grread, it's too much advanced.
smallƑish
A preview can make a more detailed idea of drafting, That is why. Example 45Rectangle program.
If it is too complicated, will try later.
Kent1Cooper
A Circle command will provide its own center-point prompt.  If you want the center point specified before the cycling through size options, then if the Circle is actually drawn first, (grread) can be used simply to determine whether to change its diameter, rather than to have a Circle drawn differently under each size choice.  Try this [lightly tested]:
(defun C:C123 (/ dia)
  (command "_.CIRCLE" pause 50)
  (while
    (and
      (princ
        (strcat
          "\nCircle shown at diameter of "
          (rtos (setq dia (getpropertyvalue (entlast) "Diameter")) 2 0)
          ". Press TAB to cycle to "
          (rtos (setq dia (+ (rem dia 300) 100)) 2 0)
          ", any other key to accept current size."
        ); strcat
      ); prompt
      (equal (grread nil 2 1) '(2 9)); pressed TAB
    ); and
    (setpropertyvalue (entlast) "Diameter" dia); change to next diameter in cycle
  ); while
  (princ)
); defun
EDIT:  Changed the cycling calculation to something a little shorter, without the (if) function, using (rem).
Kent Cooper, AIA
john.uhden
@smallƑish
If you look at what you've written (and know that the command function always returns nil) then you'll realize that option1 and option2 and option3 (had it been set) are all set to nil, and (grread nil nil nil) gets you nowhere.
John F. Uhden
Sea-Haven
Its probably not helpful but type C100 and pick a point a circle gets drawn, maybe a keep yes no, type c200 a circle gets drawn, I have  a draw circle reactor that reads the radius as part of a command. You could do some form of start rad and step into the code.
Draw a circle press + gets a unit bigger, press - gets smaller, press enter is keep. Would be easier to code.
john.uhden
@smallƑish
Ya know, another option I just thought of is to draw a circle with a diameter of 100, then offset it twice by 100, and choose the one you want by erasing the others.
OR, we could help you to draw all three with one pick, and then you choose which one to keep.
John F. Uhden
