Run Script Skip Dialogue Box
dalton98
dalton98
Sorry if this is an easy question, but I cant find an answer. I want to run a script using only the command box and not have the dialogue box pop up asking me which script to run.
I've tried..
-SCRIPT "scriptfile.scr"
-SCRIPT scriptfile.scr
/b scriptfile.scr
pendean
Community Legend
Community Legend
Where and how are you running this script/macro?
Why add the .scr, does SCRIPT command run anything else that I may have missed?
Where are your SCR files stored?
We place all SCR files in a folder that is pathed in AutoCAD's search in OPTIONS, then code it simply like this as a button for users to click on if they want that choice
dalton98
So I can store scripts in AutoCad like a template? I'm very new to this program so I don't quite know where to start.
The code is very simple and looks like this:
-LAYMRG
N
IV_INTERIOR_PROFILES
N
0
Y
-LAYDEL
N
IV_ARC_CENTERS
Y
dalton98
The reason I ask is because I'd like to run 4-5 scripts like this one at a time. I could just copy and paste every code line for line but this seemed tedious
Kent1Cooper
Two suggestions:
1.  Set the FILEDIA System Variable to 0 first.
2.  Use an AutoLisp (command) function:
(command "_.script" "scriptfile")
Kent Cooper, AIA
Sea-Haven
Are you saying make a layer then delete a layer but repeat may be easier with a lisp where you can have a list of layers and process all in one code,
(newlayer oldlayer)(newlayer oldlayer)(newlayer oldlayer)(newlayer oldlayer)
