Bring Layers' objects to Front
GeryKnee
GeryKnee
In the following lisp routine needed an if() insert to code, in order to abort i ss Collection is empty (If Layername doesn't represent any existant layer(s))
(defun C:LayerObjSendToFront (/)
(setq LayName (getstring "Layername : "))
(setq ss (ssget "X" (list ( cons 8 LayName))))
(command "draworder" ss "" "front")
(princ)
Kent1Cooper
  (if
  (princ)
Unless I misunderstand, can it be as simple as that?
Kent Cooper, AIA
GeryKnee
Hello Kent,
I can't undestand where is the error in following code
(defun fnLayerObjSendToFront (LayerName )
(if (setq ss (ssget "X" (list ( cons 8 LayName))))
(command "draworder" ss "" "front"))
(princ)
(defun c:LayerObjSendToFront(/)
(if (setq LayerName (getString "\nSpecify layer name: "))
(progn
(fnLayerObjSendToFront LayerName)
(princ)
when is executing  the following is sent
Command: LayerObjSendToFront
Specify layer name: L*
; error: bad SSGET list value
while when the same writen but with inside c:LayerObjSendToFront call (not using function fnLayerObjSendToFront ) works succesfully.
Where is the fault??
Gery
Kent1Cooper
(if (setq ss (ssget "X" (list ( cons 8 LayerName))))
Kent Cooper, AIA
GeryKnee
Thank you Kent.
A simple Checker software is necessary i think so.
Or you have to be very carefull.
Thank you very much,\Regards,
Gery.
Sea-Haven
Would it not be easier
(setq layername (cdr (assoc 8 (entget (car (entsel"\nChoose object for layer"))))))
