comments in lisp
comments in lisp
GeryKnee
comments in lisp
GeryKnee
That's a lisp function(defun fnInsertOnInsP (BlockName)
(if
(setq pt (getpoint "\nSpecify insertion point: "))
(command "_.-insert" (strcat "*" BlockName) "_NONE" pt "" "")
If i want to temporary ecclude it from .lsp fime i have to concvert it to comment
;(defun fnInsertOnInsP (BlockName)
;(if
;(setq pt (getpoint "\nSpecify insertion point: "))
;(command "_.-insert" (strcat "*" BlockName) "_NONE" pt "" "")
if pascal it's enough to convert it using
or
Is there a way like this in lisp???
CodeDing
@GeryKnee ,
What you're looking for is a multi-line comment.
They can be made like so:
(alert "Popup #1")
;; Below, is a multi-line comment
(alert "Popup #2")
(alert "Popup #3")
(alert "Popup #4")
(alert "Popup #5")
Only Popups #1 & #5 will appear when the code is ran.
Best,
~DD
GeryKnee
OK,
Thank you very much
Gery.
