Pre-defined find & replace SXH text in tables
msmith_ncl
Message 1 of 12
msmith_ncl
Hope someone can point me in the right direction, I need a simple tool to remove some values from tables.  I have an automated Bill of Materials using attributes in blocks, this generates 2 tables with objects sorted in a specific order, I also have some blocks that are used to create sub headings in these tables for types of equipment grouped together, these headings are sorted using a part code "TXTREP1" - "TXTREP6", all have a quantity of "999".  I just need want these values deleting from any table in the current drawing with 1 command,  I was using lee mac's bfind to edit these but is no longer working in 2021 with SHX text.  Also found some other tools online that worked using a script, these  were all for changing more than just tables and when running they were very slow, was quicker to just manually delete all 12 cells, attached drawing has the table as generated by the Bill of Materials and the required finished product.  Any advice is appreciated.
Replies (11)
Message 2 of 12
Kent1Cooper
Maybe not the perfect solution [because it leaves "content," though invisible, in those cells], but effective, is FIND.  Make sure Use wildcards and Table text are checked in the Options, and with a single space in the Replace with: slot, use # as the wildcard for the numbers at the end of TXTREP:
and pick Replace All.  You can do the same with the 999's without caring about wildcards.
Kent Cooper, AIA
Message 3 of 12
msmith_ncl
Thanks, I knew this, trying to find a way of doing this without any extra input, 1 mouse click, the exact same thing is done multiple times every day, I just want 1 command to remove all.  Thanks
Message 4 of 12
Sea-Haven
Try this the only issue is the test TXT123 is different to txt123 and so on ie needs a bit more about caps and lower case.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/pre-defined-find-amp-replace-sxh-text-in-tables/td-p/10160547
; find a string in a table like txt123 and replace with blank
; By Alanh March 2021
(defun c:test ( / obj str row col x y txt)
(setq obj (vlax-ename->vla-object (car (entsel "pick table" ))))
(setq str (strcat (getstring "\nSearch string prefix ") "#*"))
(vla-put-regeneratetablesuppressed obj :vlax-true)
(setq row (vla-get-rows obj))
(setq col (vla-get-columns obj))
(setq x 1)
(repeat (- row 1)
  (setq y 0)
  (repeat col
    (setq txt (vla-gettext obj x y))
    (if (= (wcmatch txt str ) T)
      (vla-settext obj x y "")
    (setq y (+ y 1))
  (setq x (+ x 1))
(vla-put-regeneratetablesuppressed obj :vlax-false)
(princ)
(c:test)
Message 5 of 12
msmith_ncl
Thanks for looking at this, I have tried the below, I can get this to remove the item numbers "TXTREP#" from each table but the "999" qty is still there, am I doing something wrong?
Also, I need to run the command twice to pick each table separately, if possible, I'd prefer to just run the command and it auto clears those cells in any table in the current drawing without needing to pick a table.
Message 6 of 12
pbejse
Use this if you want something  specific to same target, always "TXTREP#" and thq quantity column regardless
(defun c:deltextrep (/ ss i evt n)
  (if
    (setq ss (ssget "_X" '((0 . "ACAD_TABLE"))))
     (repeat (setq i (sslength ss))
       (Setq evt (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
       (vla-put-regeneratetablesuppressed evt :vlax-true)
       (repeat (- (setq n (vla-get-rows evt)) 2)
	 (if
	   (wcmatch (vla-gettext evt (setq n (1- n)) 0) "TXTREP#*")
	   (progn
	     (vla-settext evt n 0 "")
	    (vla-settext evt n 3 "")
       (vla-put-regeneratetablesuppressed evt :vlax-false)
 HTH
Message 7 of 12
Sea-Haven
Like pbe I have updated the code, what do you mean by "999" not changing if you want specific value need to change code for  prefix or actual..
(defun c:test ( / ss obj str row col x y txt)
(repeat (setq x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq x 1)
(repeat (- row 1)
  (setq y 0)
  (repeat col
    (setq y (+ y 1))
  (setq x (+ x 1))
(princ)
(c:test)
Message 8 of 12
msmith_ncl
This is perfect, thanks again
Message 9 of 12
msmith_ncl
Sorry to be a pain, I have just run into another issue and hoping it can easily be included in this routine.  My bill of materials tool uses external text support files to add items into the tables, I have just started using items with inch symbol in the part number and description and for some unknown reason the " symbol is being doubled every time and appearing in the table as "".  Would be a massive help if those double quotes in the table can all be replaced with single quotes using the same tool that already empties other cells.
support text file below
Result from Bill of materials tool
Message 10 of 12
pbejse
@msmith_ncl wrote:
Sorry to be a pain, ...
  (if
	 (if
	    (progn
	 (if (wcmatch  (setq str (vla-gettext evt n 1)) "*\"\"*" )
	   (progn
	   	(While (vl-string-search "\"\"" str)
		  	(setq str (Vl-string-subst  "\"" "\"\"" str))
	     (vla-settext evt n 1 str)
HTH
Message 11 of 12
msmith_ncl
Thanks again, that's awesome
Message 12 of 12
pbejse
Cool beans , You are welcome.
