Break all lines at a boundary
kzD1219
kzD1219
Is there any way to break multiple lines that intersect at a closed polyline boundary?  I have many lines to break at a boundary and was hoping for a quick way.  I have attached an image.  I have to break all lines at the red polyline since inside the polyline the linework will be one color and outside the red boundary they will be another color.
marko_ribar
Try this lisp by CAB, but still you have to work to color correct lines as desired...
P.S. You have to be logged to download...
https://www.theswamp.org/index.php?topic=10370.0
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
ВeekeeCZ
I would recommend nice routine as @marko_ribar posted by CAB on theswamp.org
Unfortunately the original routine is not available at the moment, so I've attached previously downloaded version. Here is description of the routine:
Kent1Cooper
Another possibility is >here<.  Also look around that site -- I think there are other similar routines there, with different specifics.
Kent Cooper, AIA
ВeekeeCZ
@Kent1Cooper wrote:
Another possibility is >here<.  ...
You're referring to the same routine but older version.
john.uhden
While we're at it, is there already a routine that would trim a grid of lines outside the boundary of a closed 2D polyline?
Hmm, I think it would be easier to hatch the polyline and then explode the hatch.
John F. Uhden
