getpoint's output vs list
Is getpoint's output equal to '(1.0 2.0)?
Here's what i'm trying to do:
 (setq pt3 '((- x1 pt1x) (- y1 pt1y)))
 (setq pt4 '((+ x1 pt2x) (+ y1 pt2y)))
 (command "_ellipse" pt3 pt4 axe2)
marko_ribar
Apostrophe in lisp syntax is treated literally, so this won't work :
Instead you should force ACAD to evaluate expressions using (list) function :
Now if x1, pt1x, y1, pt1y, pt2x, pt2y are reals stored in those variables, this should work :
 (setq pt3 (list (- x1 pt1x) (- y1 pt1y)))
 (setq pt4 (list (+ x1 pt2x) (+ y1 pt2y)))
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Ranjit_Singh
Call the getpoint function at AutoCAD command prompt and pick a point. You will see that it consists of x, y and z coordinates. If the elevation of resulting ellipse does not matter then ignore z co-ordinate and the ellipse will be at default elevation. As pointed out in post 2, use list instead of quote.
dbroad
Another approach.  For mapcar, the shortest list governs the result.
(setq p1 '(1.0 2.0) ;;assumed half major axis offsets from center
      p2 (getpoint "\nPick point: ") ;;assumed center point
(setq p3 (mapcar '- p2 p1)
      p4 (mapcar '+ p2 p1)
(command "._ellipse" p3 p4 pause)
Architect, Registered NC, VA, SC, & GA.
