Good day everyone,
I am right now working with a point cloud to create a section view.
To automate the process using autolisp scripting, it is essential to know the boundary box of the point cloud. As it can be seen on the pictures, a grey box is drawn after inserting PC to modelspace.
I tried using the model tree and files manager, and other properties, but there is no way to identify boundary box of the point cloud.
I am guessing that there should be a method, since autocad automatically draws a box.
If not, it would be great if I can at least identify maximum and minimal x,y,z values of the box. Thank you very much!
Solved by Ranjit_Singh1. Go to Solution.
Hi cjf96cjf try the below code
(defun c:somefunc (/ vlaobj) (setq vlaobj (vlax-ename->vla-object (car (entsel "\nSelect point cloud :")))) (and (= "AcDbPointCloud" (vla-get-objectname vlaobj)) (vla-getboundingbox vlaobj p1 p2)) (princ (strcat "\nLower left corner :" (vl-princ-to-string (safearray-value p1)) "\nUpper right corner :" (vl-princ-to-string (safearray-value p2)) "\nLength :" (rtos (vla-get-length vlaobj) 2 4) "\nWidth :" (rtos (vla-get-width vlaobj) 2 4) "\nHeight :" (rtos (vla-get-height vlaobj) 2 4))) (princ))
Thank you very much for help, but I seem to have resolved the issue by myself. I will upload my code soon so you can review it too.
Thanks for help!
I want to crop my pointcloud with à lisp routine.
Il try to modify entity dxf group "13" (4 points) and entmod, entupd, but it doesn't work.
Do you have an idea to help me ?
Thank you.
