BOLT COUNTING BY LAYER
Gaganpatel
Message 1 of 30
Gaganpatel
Dear Sir,
I want to bolt counting by layer, counting only select text (after & before)
Please see the attached file.
Layer Name : BN1 x 1=
Layer Name : BN2 x 2=
Layer Name : BN3 x 3=
Layer Name : BN4 x 4=
Total Quality : = BN1+BN2+BN3+BN4
M16x35mm =
M16x40mm =
M16x45mm =
M16x50mm =
M16x55mm =
4 Thk Washer =
5 Thk Washer =
6 Thk Washer =
8 Thk Washer =
10 Thk Washer =
Replies (29)
Message 21 of 30
ec-cad
Do you mean you want "change" selected Text to be on Layer BN1 BN2 BN3 or BN4 ?
That can let you select multiple  pieces of 'Text' and merely change to one of those layers ?
ECCAD
Message 22 of 30
Gaganpatel
Dear Sir,
how to change bolt text layer from BN4 to BN2 layer
Example
Qty. change require BN4 to BN2
Message 23 of 30
ec-cad
OK, last change.
This lisp will allow you to pick which text (from any layer), ask you to change it to one
of the BNx layers. You Appload it, and it will run (once) when loaded. Once you load it,
you can just type in CHGTXT to run it again.
If you respond 1 or 2 or 3 or 4 to the prompt, it will change it. If you just hit Enter, it will exit.
Makes the target layer if it doesn't exist.
If both of the Lisps are 'done' and work for you, please check this Post as Solved.
ECCAD
Message 24 of 30
Gaganpatel
Dear Sir,
Please help, I have tried only table showing Bolt qty. Not showing.
Message 25 of 30
Sea-Haven
 Did you select the text ? Thats all I can think of its working for me.
Message 26 of 30
ec-cad
This modification will do a report by Layer, as well as Totals.
Watch the prompt line, pick the window, pick a point for Layer by Layer, and pick point
for Summary.
By the way, did the CHGTXT function do what you wanted ?
ECCAD
Message 27 of 30
Gaganpatel
Dear Sir,
Many Many Thanks Working very good.
Please give your email id,
Message 28 of 30
ec-cad
Sent you a private message on email address.
Please do not post it here.
Oh, please mark this topic as 'Solved'
ECCAD
Message 29 of 30
Gaganpatel
Dear Sir,
I want to new programming required for select drawing Bold text only highlighted. For Bolt checking, purpose.
Please help.
Message 30 of 30
ec-cad
Bool_Tools.lsp (new)
When loaded, it has (2) functions that you type-in at the Command Prompt.
First is  CHKW  means check bolt text within a Window, does multiple.
It will throw up the Textscreen, but you can remove that with the F2 key on your keyboard.
Reports it's findings to the Command Line, and shows up with the Textscreen on.
Second is  CHKS  means check a single bolt text. You pick one, and it will give you the info
in an Alert dialog window, just hit the OK, then Enter key if you want to see more..
Hope you like them.
Bye the way, did you get a 'Private Message', I sent you one with my email.
ECCAD
