Difference between 2 text values and the result as a text.
symoin
symoin
Hi Everyone,
I have a situation Where I need to find the difference between 2 layers (Before and after) and write the result in another layer (Difference). The drawing has points with elevations and the text as elevation labels, I need to write the difference in the Z value Elevations near the location. I there any way this can be achieved in one go rather than each pair of text (selecting 3 points)? There are more than 2500 pairs of such points.
The attached drawing is for reference.
komondormrex
hey,
check this one
(defun c:diff (/ bp_sset +bt_size -bt_size bt_insertion ba_sset z_diff diff_text)
	(princ "\nSelect \"BEFORE\" texts...")
	(if (setq bp_sset (ssget '((0 . "text") (8 . "before"))))
		(foreach b_text (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex bp_sset))))
			(setq +bt_size (* 2 (vla-get-height b_text))
				  -bt_size (* -1 +bt_size)
				  bt_insertion (vlax-get b_text 'insertionpoint)
				  ba_sset (ssget "_cp"
				  				 (mapcar '(lambda (point_1 point_2) (mapcar '+ point_1 point_2))
								 		  (list (list -bt_size -bt_size) (list -bt_size +bt_size) (list +bt_size +bt_size) (list +bt_size -bt_size))
								   		  (list bt_insertion bt_insertion bt_insertion bt_insertion)
								 '((0 . "text") (8 . "after"))
				  z_diff (- (atof (vla-get-textstring b_text)) (atof (vla-get-textstring (vlax-ename->vla-object (ssname ba_sset 0)))))
				  diff_text (vla-copy b_text)
			(vla-move diff_text (vlax-3d-point bt_insertion) (vlax-3d-point (mapcar '+ bt_insertion (list 0 (* -1.65 +bt_size) z_diff))))
			(vla-put-textstring diff_text (rtos z_diff 2 3))
			(entmod (append (entget (entlast)) '((8 . "DIFFERENCE"))))
	(princ)
updated
symoin
Thank you komondormrex,
This is a great code and is as I need. Here I have noticed its nor working on a few text values. I have attached the Snap , look at the command prompt.
Further I request you for another update. like :  if there are no text and only points are available in the drawing. Can we calculate the differences from the point elevations?
Thanks once again for the help.
komondormrex
check update with increased fuzz to select text. will see the option with points only later on.
komondormrex
hey,
here you go
(defun c:z_diff (/ bp_sset +bp_size -bp_size bt_insertion ap_sset z_diff)
	(princ "\nSelect \"BEFORE\" points...")
	(if (setq bp_sset (ssget '((0 . "point") (8 . "before"))))
		(foreach b_point (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex bp_sset))))
			(setq +bp_size (* 2 (getvar 'pdsize))
				  -bp_size (* -1 +bp_size)
				  bt_insertion (vlax-get b_point 'coordinates)
				  ap_sset (ssget "_cp"
								 		  (list (list -bp_size -bp_size) (list -bp_size +bp_size) (list +bp_size +bp_size) (list +bp_size -bp_size))
								 '((0 . "point") (8 . "after"))
				  z_diff (- (caddr bt_insertion) (caddr (vlax-get (vlax-ename->vla-object (ssname ap_sset 0)) 'coordinates)))
			(vla-addtext (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
						 (rtos z_diff 2 3)
						 (vlax-3d-point (mapcar '+ bt_insertion (list 0 (* -1.65 +bp_size) z_diff)))
						 (if (null text_size) (setq text_size (getreal "\nEnter marking text size: ")) text_size)
	(princ)
