BOLT COUNTING BY LAYER
Gaganpatel
Message 1 of 30
Gaganpatel
Dear Sir,
I want to bolt counting by layer, counting only select text (after & before)
Please see the attached file.
Layer Name : BN1 x 1=
Layer Name : BN2 x 2=
Layer Name : BN3 x 3=
Layer Name : BN4 x 4=
Total Quality : = BN1+BN2+BN3+BN4
M16x35mm =
M16x40mm =
M16x45mm =
M16x50mm =
M16x55mm =
4 Thk Washer =
5 Thk Washer =
6 Thk Washer =
8 Thk Washer =
10 Thk Washer =
Replies (29)
Message 2 of 30
Gaganpatel
Dear Sir,
Anybody please help me
Message 3 of 30
ec-cad
Try this Lisp out. Do an Appload of it from disk. (files of type '.lsp').
When loaded, just type GO to start the program.
I hope this gets you started.
ECCAD
Message 4 of 30
ec-cad
Oh, forgot to mention, it doesn't (output) the results, just echo's them to the TextScreen.
If you don't see anything happen, just hit the F2 key to throw up the TextScreen.
If you need a Table built, maybe someone here will do that. Or if you need a .csv file for Excel,
I'm sure someone can do that also.
ECCAD
Message 5 of 30
ec-cad
Hmm,
I see some 8-20x45 's in there. Are there more bolt sizes than were mentioned in Post ?
ECCAD
Message 6 of 30
Gaganpatel
Dear Sir,
Thanks for reply.
I want to many types bolts counting, select person bolts counting only not complete drawing bolts count, final total qty. place in text select location in auto cad drawing.
Types of Bolts & Washer
1) M16x35 to M16x130 (bolts)
2) M20x35 to M20X180 (bolts)
3) M24x40 to M24x190 (bolts)
4) M16 4tHK to M16 12THK (washer)
4) M20 4tHK to M20 12THK (washer)
4) M24 4tHK to M20 12THK (washer)
Message 7 of 30
Sea-Haven
Another makes table.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bolt-counting-by-layer/td-p/12726828
(defun c:boltcnt ( / ss ent str pos num1 str2 lst lst2 lst3 numrows numcolumns rowheight colwidth doc curspc pt )
(setq ss (ssget '((0 . "TEXT"))))
(setq lst '())
(repeat (setq x (sslength ss))
(setq ent (ssname ss (setq x (1- x))))
(setq str (cdr (assoc 1 (entget ent))))
(setq pos (vl-string-position 45 str))
(setq num1 (atoi (substr str 1 pos)))
(setq str2 (substr str (+ 2 pos)))
(repeat num1
(setq lst (cons str2 lst))
(setq lst (vl-sort lst '(lambda (x y) (< x y))))
(defun my-count (a L)
  (cond
   ((null L) 0)
   ((equal a (car L)) (+ 1 (my-count a (cdr L))))
   (t (my-count a (cdr L))))
; By Gile
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
(setq lst2 '() lst3 '())
(setq lst2 (remove_doubles lst))
(foreach val lst2
    (setq cnt (my-count val lst))
    (setq lst3 (cons (list val cnt) lst3))
(setq numrows 3)
(setq numcolumns 2)
(setq rowheight 8)
(setq colwidth 40)
(setq doc  (vla-get-activedocument (vlax-get-acad-object) ))
(if (= (vla-get-activespace doc) 0)
(setq curspc (vla-get-paperspace doc))
(setq curspc (vla-get-modelspace doc))
(setq pt (vlax-3d-point (getpoint "\nPick point for table ")))
(setq objtable (vla-addtable curspc pt numrows numcolumns rowheight colwidth))
(vla-setcellalignment objtable 0 0 acMiddleCenter)
(vla-setcellalignment objtable 1 0 acMiddleCenter)
(vla-setcellalignment objtable 1 1 acMiddleCenter)
(vla-setcellalignment objtable 2 0 acMiddleCenter)
(vla-setcellalignment objtable 2 1 acMiddleCenter)
(vla-SetTextHeight objtable acHeaderRow 3)
(vla-SetTextHeight objtable acTitleRow 3)
(vla-SetTextHeight objtable acDataRow 3)
(vla-settext objtable 0 0 "Bolt table")
(vla-settext objtable 1 0 "Bolt size")
(vla-settext objtable 1 1 "Count")
(setq objtable (vlax-ename->vla-object (entlast)))
(vla-put-regeneratetablesuppressed objtable :vlax-true)
(vla-SetAlignment Objtable (+ acDataRow acHeaderRow acTitleRow) acMiddleCenter)
(vla-SetTextHeight objtable (+ acDataRow acHeaderRow acTitleRow) 3)
(setq rows 2)
(foreach cellline lst3
(vla-insertrows objtable rows 8 1)
(vla-settext objtable rows 0 (car cellline))
(vla-settext objtable rows 1 (rtos (cadr cellline) 2 0))
(vla-SetcelltextHeight objtable rows 0 3)
(vla-SetcellTextHeight objtable rows 1 3)
(vla-SetcellAlignment objtable rows 0 acMiddleCenter)
(vla-SetcellAlignment objtable rows 1 acMiddleCenter)
(setq rows (1+ rows))
(vla-put-regeneratetablesuppressed objtable :vlax-false)
(princ)
(c:boltcnt)
Message 8 of 30
Gaganpatel
Dear Sir,
Thanks for reply.
AutoCAD 2013 use . Output Bolt qty not show only table show.
Message 9 of 30
ec-cad
This Lisp will count bolts & washers per your new list of bolt & washer sizes. Lots of Counters in there.
Attached is the Lisp and a sample drawing.
Do an Appload (files of type .lsp), when loaded, just type GO to call the function.
It will count up the totals and ask you to pick a point to add-in the Text report.
If the Text height is too large, let me know..I based that on the sample drawing.
Hope you like it.
ECCAD
Message 10 of 30
ec-cad
Minor correction for one of the M24 counters. Fixed that.
Here's the final version.
ECCAD
Message 11 of 30
Gaganpatel
Dear Sir,
Many Many Thanks
Please do some modification.
Not total bolt counting on the drawing sheet, only select bolt counting on the drawing sheet.
Message 12 of 30
Sea-Haven
This is what I get
Added more bolts for a better count
The table needs to be scaled up as I guessed the size.
Message 13 of 30
ec-cad
Sure. You now 'pick upper left, and lower right points. Program will get the text to process in the
Selection Window points. Will list all bolts / washers just within the Window on the Layers BN1 BN2 BN3 BN4.
If you need anything else, just let me know.
ECCAD
Message 14 of 30
Gaganpatel
Dear sir,
I have tried select first window point uper left and other window point lower right but text are not selected output results not showing.
Message 15 of 30
Gaganpatel
Dear Sir,
Only table create not bolt counting, One modify please select required only Bolt Text not other text.
Message 16 of 30
ec-cad
When I added the Window selection, I didn't filter out all but Text. This update will work as expected.
Sorry about that. My bad.
ECCAD
Message 17 of 30
Gaganpatel
Dear Sir,
Please some modification required.
Change Layer: select Bolt text choose layer name Option:BN1 BN2 BN3 BN4
Message 18 of 30
ec-cad
I do not understand the question.
You wanted to get the count by selecting those items. That I did.
Do you want to select just some items within that window, by specifying which Layer ?
If so, I need to ask you which layer 1, 2, 3 or 4 ? That I can do. You would get a total count for those
that are on (1) layer. You would have to run it 4 times to get a total count, unless an option would
be 1,2,3,4 or A for all. So, what is it you need ?
ECCAD
Message 19 of 30
Gaganpatel
Dear Sir,
I want to new programming for layer change of bolt text .
Message 20 of 30
ec-cad
Could you make up a drawing of  "layer change of bolt text". to show me what you mean exactly.
What layer do you want me to 'change' it to ?
I'm confused.
ECCAD
