Blocks Perpendicular to Polyline
adaptacad
adaptacad
Good morning, everyone!
I would like to know if it’s possible to align multiple blocks so that they are perpendicular to polylines in a DWG file.
The goal is to select multiple texts and multiple polylines, ensuring that the texts align perpendicularly to the nearest polyline. I've searched on Google and ChatGPT but haven’t found a solution.
Can anyone help me? I’ve attached images and a DWG file as examples.
Thanks in advance!
ВeekeeCZ
Not search, not ai, just learn. There is nothing complicated. Nothing.
(vl-load-com)
(defun c:BlocksPerpendiculartoPolyline ( / s d b l c q a)
  (and (setq s (ssget '((0 . "LWPOLYLINE,INSERT"))))
       (setq d (getdist "\nSpecify distance: " ))
       (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
       (foreach e s
	 (if (= "INSERT" (cdr (assoc 0 (entget e))))
	   (setq b (cons e b))
	   (setq l (cons e l))))
       b
       l
       (foreach e b
	 (if (and (setq p (cdr (assoc 10 (entget e))))
		  (setq l (vl-sort l '(lambda (l1 l2) (< (distance p (vlax-curve-getclosestpointto l1 p))
							 (distance p (vlax-curve-getclosestpointto l2 p))))))
		  (setq c (car l))
	   (progn
	     (setq q (vlax-curve-getclosestpointto c p))
	     (setq a (angle q p))
	     (setpropertyvalue e "Rotation" a)
	     (setpropertyvalue e "Position" (polar q a d))))))
  (princ)
adaptacad
Thank you very much @ВeekeeCZ !!!! This worked very well! But is there a way to keep the original distance, without having to specify it?
ec-cad
If you want the original distance maintained, try the revised code:
(vl-load-com)
     ;; (setq d (getdist "\nSpecify distance: " )); we want to keep original distance
       (foreach e s
	   (setq b (cons e b))
       b
       l
       (foreach e b
		  (setq c (car l))
	   (progn
             (setq d (distance q p)); Set the Distance to what it was..
  (princ)
;; remove next 2 lines if desired for autoloading
 (c:BlocksPerpendiculartoPolyline)
 (princ)
ECCAD
adaptacad
Thank you both very much! It worked great! @ВeekeeCZ  @ec-cad
