Block circle to block circle dimension only text.
Gaganpatel
Gaganpatel
Hi every one,
I have block circle to block circle dimension only text autolisp file.
Please see the example file.
Thanks & Regards
Kalandi Paital
Gaganpatel
Hi every one,
Thanks & Regards
Kalandi Paital
Kent1Cooper
Is there a difference between "Block circle" and "Circle block" on this other thread with most of a solution?  Is there anything else different in what you're asking for on the two threads?
It's not a good idea to have more than one thread going on the same subject.  If there is a solution on one of them, and someone else has a similar need, they may find the one that does not  have the solution.  If you get a final solution on one of them, at least post something on the other linking to it.
Also, is it just a mistake that the long adding-up text string includes the values of all but one  of the Dimensions?  It's missing the last one -- should that be included?
Kent Cooper, AIA
